Parts wanted for Case IH 275
   / Parts wanted for Case IH 275 #1
BrokenParts
IH275
Is there anyone that has this Case IH 275 compact tractor for parts? I am looking for a complete 1962079C1 drop box front pto assembly. I need a 1962383C1 tachometer. I am also missing all my 3pt hitch draw bars and links as well as the lever controls and cover plate. If youæ±*e close enough i'd love to pick up a 10QA or equivalent loader too. Thanks
Still looking for parts.
Thanks for the reply however these are not Case IH 275 compact tractors they are International Harvester swathers. I have contacted Wreckers at TractorHouse and none seem to have the parts I need for the Case IH 275 4x4 compact.
   / Parts wanted for Case IH 275 #4
Yes these are Case IH 275 compact tractors however only a few are 4x4 and I have contacted these Wreckers at TractorHouse for the parts. Unfortunately not all 4x4s had the front PTO part I need and the Wreckers seem to have sold the tachometers and three point hitch systems already but thank you anyways.
   / Parts wanted for Case IH 275 #6
apparently, if it has 4 wheel steering, you can't put a front loader on it anyway.. maybe the other parts you need can be adapted for this tractor..
It's an old girl so just front steering. Yes some other parts may work for the 3pt hitch, tach & loader but not the Dropbox. Id like to use oem and bring back it's glory.
   / Parts wanted for Case IH 275 #8
   / Parts wanted for Case IH 275 #9
That era of IH and Case IH compact tractors were made by Mitsubishi. Some of the Mitsubishi models shared a lot of crossover to some of the Case IH models. I think the Mitsubishi MT300D shared a lot of parts with the Case 275, so you may have some luck if you search parts from the MT300D. West Kentucky Tractor Parts shows on their website that they have both CIH 275 and MT300 parts tractors in their inventory.
The 275's mid PTO option was available on 2 and 4WD models and used the same parts so don't automatically ignore any 2WD models for those parts.
   / Parts wanted for Case IH 275 #10
Sorry, right number, wrong category... Glad radios1 found the right category for you. Hope someonehas the parts you need..!!
ITEM LOCATION (A53084)
2008 JOHN DEERE 672D MOTOR GRADER (A52705)
2008 JOHN DEERE...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
CATERPILLAR 226D SKID STEER (A52705)
CATERPILLAR 226D...
