Snow Cab Heat
/ Cab Heat #1
Jimbos
Mahindra 25s cab
Good afternoon, my first post on this site and a first time diesel owner.
I bought an Emax 25s Cab about a month ago along with the snowblower, loader, and box blade.
I live in the NW Lower Michigan snow belt area and needed a tractor with a heated cab after getting sick of blowing snow with a Deere lawn tractor and coming back in looking like a snowman after doing my 1/4 mile drive.
I love the tractor and it's doing what it's supposed to do but I have a couple of questions.
It was smoking like crazy bad at anything over 2500 rpm which the dealer said was a fuel issue and to add an additive which seems to of helped, is that all there was to it?
But my main gripe is cab heat. It was blowing luke warm air, so after a call to the dealer he sent his mechanic out to the house to change out a 160 degree thermostat for a 180 one which has helped slightly, they also said to do the cardboard trick which helps, with the air blowing warm for about 25 minutes then goes back to a tepid luke warm air temp.
Does anyone have any ideas to correct that?
P.S. The outdoor air temps have been in the 10-25 degree range, am I just expecting too much?
/ Cab Heat #2
My 2555 HST 55hp turbo charged behemoth did the same thing. The tractors are designed to run in fairly hot climates and not overheat when you work them hard in that heat. In the case of my 2555, they put in an over aggressive fan that sucks about twice as much air thru the radiator as my other tractors. I put a piece of Wally sign plastic [ about 1/4" thick, assorted colors ] in front of my radiator with an 8-1/2" hole in up centered on the center of the fan on the other side of the radiator. I originally had a 7-1/2", but that turned out to be too much restriction when really working the tractor hard in the winter. Without blocking the radiator some, or putting a winter front on the outside of the grille, the fan over cools the system so even a higher thermostat does not help a lot. You can try blocking the air some, but you must keep an eye on the temp gauge more than ' normal '. With the air flow restricted, my tractor actually gets too hot inside the cab when blowing snow for a long period. And I have to turn the temp down some, keeping the blower at max to keep the windows clear.
/ Cab Heat #3
At what temps do you see blocking the radiator making a difference or at what temp do you put your plastic in to block it? Even at about 15 degrees F out my 2655 HST Cab throws enough heat after 10 minutes of warming up that I can wear a t-shirt in the cab and be comfy though I usually just turn the heat down. When plowing snow after the first 20 minutes anything less than half way on the temperature setting gets too hot in the cab. Pretty sure your Michigan temps are a bit colder than here in New Hampshire though.
/ Cab Heat #4
Your manual probably states you should cover your grill when it’s cold. I assume the engine isn’t coming up to temp and taking heat from the engine for the heater isn’t helping. Get some type of grill cover for the outside or inside of the grill- note I didn’t say radiator. The radiator grill would be a little more complex. With the cover installed be sure to monitor engine temps.
Yes the smoke is normal if the fuel is starting to gel. The additive helps with gelling. It’s easy to do with lightly used tractors. Folks buy the fuel in the summer and run it in the winter. Fuel stations switch from summer to winter blends in cold areas.
/ Cab Heat
What about a 200 degree thermostat? I gave it a thought but it's showing a warm up coming late next week so I thought it might be too late for that.
I wish this thing had an actual gauge and not an idiot light to verify temps.
/ Cab Heat #6
Don’t mess with a different thermostat- bad for the engine and it ain’t coming up to temp a different thermostat won’t help.
/ Cab Heat #7
I'd keep restricting air over the radiator until you get heat. As others have said, watch the temperature gauge. On my little B series Kubota, I found the heater I'd installed was enough to cool the whole engine in winter -i.e. I could block off the whole radiator.
/ Cab Heat #8
I block my radiator in the fall when I put the snowblower on, and take it off with the blower in the spring. I did the same thing with my Dodge Cummins when I ran it in the winter years ago. A lot of folks up in our U.P. do it to their cars all winter, usually putting in a sheet of cardboard ahead of the radiator. Truckers have been doing it as long as I can remember.
/ Cab Heat
Gotcha, thank you
/ Cab Heat
I'll play around with the cardboard to see if that helps, we have this extra cold snap happening this week so later this week I'm sure I'll have to blow.
/ Cab Heat #11
I block off the lower half of my radiator. Before that I couldn't get my tractor up to temperature but now the engine warms up nicely and so does the cab.
/ Cab Heat #12
If your wife sews, you could get her to make a fitted blanket for the whole tractor hood. Maybe out of old blankets or something insulated. It is very effective and with just a bungie cord underneith, easy to take on and off. Diesels use a lot of air and don't warm up well in the cold.
/ Cab Heat #13
What about a block heater. In conjunction with covering the radiator some?
/ Cab Heat
I got it figured out, I moved the cardboard down to the bottom, and actually cut some back which, and it's been blowing a nice temp.
/ Cab Heat #15
Yup, cardboard does the trick. I am in my first winter with the Emax 25 cab and up here anything about -8C and colder it dos not like at all. I could not get to proper PTO RPM's and it would spew a stinky white smoke and it sounded very tinny. And as you said the cab heat was just warmish. So I tried covering 3/4 of the rad with card board (i think about -18 that day). Let it run for a bit and went to blow and wow what a difference. The cab nice and toasty, no white smoke at high RPM and the engine sounded 100 times better (normal).
It is warmer now so I need to be aware of how much rad i cover but so far no issues.
Other than that do how do you like the tractor?
2017 CATERPILLAR 262D SKID STEER (A62129)
2017 CATERPILLAR...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2014 FORD F150 4X4 PICKUP TRUCK (A59906)
2014 FORD F150 4X4...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
