Regeneration question
/ Regeneration question #1
nancyk
east Tennessee
Deere 5055e 2015, Ferris IS2000z 2007
My Deere 5055e has just over 250 hrs on it. Last September the Regeneration light came on. The Deere man told me to push and hold the Regeneration button for a few seconds, while the tractor was running. The light finally went out so I suppose the process worked. I used the tractor for light mowing during this process. I re-read the owners manual this morning, it said if the Regeneration light comes on, you should do a Parked Exhaust Filter Cleaning for at least 30 minutes. Should this be done on a regular basis even if the light does not come on? This tractor does not do much heavy work, mainly bush-hogging, finishing mowing and spraying the driveway for weeds.
P.S. After doing more reading on the internet, it appears others are confused as to when their tractor needs Regeneration, and how to do it. The owners manual is not very helpful. It seems it is not necessary to do a Regeneration until the light does come on. That being said, those lights on the dash are confusing as to what they mean. It took me forever to figure out what the symbol meant.
/ Regeneration question #2
Well, My Deere doesn't have to regen...but my Kubota does so all I can tell you is how the Kubota system works as it might be similar.
When the Regen light comes on on the dash, it means that the tractor is going through a regen cycle. YOU don't have to do anything except keep working the tractor, and that means keep the rpms over 1500 (at least on the Kubota). When the regen cycle is done the light goes out. Now, there is a manual, or "Parked" regen that I can initiate on the Kubota by pushing another button. Then I can park the tractor with rpms up high and leave it until the regen is done. I've never done a manual regen - never found a need for it.
When I first got the Kubota I too was very confused about how this regen thing worked. I found out it is really not a big deal at all. If the light comes on while I'm working I just make sure I keep on working until the light goes off. Do not shut down the tractor while it is regenerating. If you do so, that's when you may have to do a manual (Parked) regeneration because that soot build-up in the DPF will need to be burned off.
"When the Regen light comes on on the dash, it means that the tractor is going through a regen cycle. YOU don't have to do anything except keep working the tractor"
Interesting. That was not the impression I got from reading the Deere manual. Thank you so much for answering this, there is so much I do not understand about these tractors.
Nancy
/ Regeneration question #4
Nancy
I don't own anything orange or green with a DPF on it. But the systems seem to be too much confusing for the operators.
First of all, no panic when a light comes on. You need to understand what the different lights mean.
There is the warning light that comes on when a regeneration is in progress. It warns the operator of hot exhaust gases and hot exhaust components. The operator does not have to interfere. Keep on working.
Except, due to the hot exhaust, for the example the machine is operated in a hay shed, you don't want that regeneration to happen in there due to the fire hazard. Now the operator wants to depress the regeneration and pushes the "cancel" button. An automatic regeneration cycle might be initiated by machine at some point later OR it is asking for a "Parked Regeneration".
/ Regeneration question #5
My Deere 5055e has just over 250 hrs on it. Last September the Regeneration light came on. The Deere man told me to push and hold the Regeneration button for a few seconds, while the tractor was running. The light finally went out so I suppose the process worked. I used the tractor for light mowing during this process. I re-read the owners manual this morning, it said if the Regeneration light comes on, you should do a Parked Exhaust Filter Cleaning for at least 30 minutes. Should this be done on a regular basis even if the light does not come on BLOODMONEY 2? This tractor does not do much heavy work, mainly bush-hogging, finishing mowing and spraying the driveway for weeds.
You don’t need to do a parked regeneration unless the light comes on; just run the tractor under load regularly so it can complete automatic regeneration on its own.
/ Regeneration question #6
My Yanmar (new) does this ‘passive regen’ and you keep working or park it and let it finish; approx 30 min at min 2200 rpm.
The key is to work these engines to what the manual says. I’m used to running a diesel tractor with just enough rpm’s to get it done. My Yanmar says to run at much higher rpm’s. If I piddle around with it, I’ll get more recent regens. If I run it hard; higher rpm’s, not as often.
/ Regeneration question #7
Unless things changed since 2020 you don't touch anything when the regen starts. Especially the regen button. That's why it has an auto setting. Just keep working until it finishes. Mine has gone through 2 or 3 I think. They initiate when you get to about 98% soot level. Usually around 200 hours for me.
My 5055e regen comes on every 50 hours, so twice a year for me. I keep the rpms at least 12000 and attempt to keep using the tractor, not just idling it. The process does seem to take around 30 minutes.
/ Regeneration question #9
Nancy
About the only thing more confusing than Deere's cryptic pictorial indicators and buttons, is their user manual. It doesn't help that they've changed the basic operation and indicators on this system so many times, that no two documents or YouTube videos on the subject seem to match.
Here's the basics:
  1. Your tractor has an diesel particulate filter (DPF) on the exhaust, that fills up with sediment which must be burned off every 50 - 100 hours.
  2. Under normal circumstances, your tractor will execute a regular "operating" regen cycle, and automatically take care of this. You don't need to do anything, just keep the tractor running until it's completed. Depending on exact year and model, the tractor will either automatically increase engine speed above 1500 RPM, or it will flash a message on the dash asking you to do it. Just keep engine speed above 1500 rpm for the 15 - 20 minutes it takes this cycle to complete. No need to park it, just keep working.
  3. If regen starts at an inconvenient or unsafe time, there's a button to disable it. It will try again the next time you run the machine.
  4. If there is a problem with normal "operating" regen, or if DPF gets super-nasty, your indicators or digital display may tell you that you need to do what's called a "parked" regen. You can also execute a parked regen anytime you want, such as if you had previously bypassed the tractor's automatic "operating" regen.
    1. Parked regen gets the filter cleaner, you'll notice soot level reports as 0% when it's complete, versus something like 20% at the end of a regular operating regen.
    2. You must remember to put the transfer case in neutral when running a parked regen, so the tractor isn't spinning everything downstream of it while sitting parked.
So @deserteagle71 has it right: under normal regn, there's no need to do anything... just keep working. You only need to stop and do a parked regen under rare and special circumstances.
And if I ever meet the guy at Deere who came up with the system of regen indicators on my tractor, I'm going to kick him square in the nuts, for making a system that's infinitely more confusing than it really needs to be.
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2019 Ford F-450 Flatbed Truck (A64194)
2019 Ford F-450...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
