Tractorpacker anyone??
/ Tractorpacker anyone?? #1
hunt4570
Super Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
So I don't have a cultipacker.. someday maybe.. So I devised my own method on my food plots...TRACTORPACKER!!
So I disc if needed, harrow, seed, and then just drive back and forth till I press all the seed into the soil , ok maybe not soil, more like slightly dirty sand
And here's a couple fields I did this with about a month or so ago...
/ Tractorpacker anyone?? #2
That's what I do also but on a smaller scale. Just little places I dig up.
I have to have some moisture in the ground when I do it, otherwise my ground is like dry beach sand and wont pack. So I try to do it right after a rain.
/ Tractorpacker anyone?? #4
Yup done that before,
... Now I have a cultipacker, and it does make a difference, especially on small seed stuff, and saves making so many passes over the area. LOL
....I needed mine right away, so ended up buying new, but if you are patient, they come up for sale on Craigslist often..
.. I actually just got the last of several fall/winter foodplots seeded last week, with the rain over the weekend, and current forecast, they should do pretty well.
I keep watching Craigslist and I only see drag models come up, keep hoping a 3 pointer will come up cause new ones are in excess of a grand!! I'll not get a drag model, to much of a pain to deal with.
And yeah driving back and forth is a pain too.. but I have time these days..
/ Tractorpacker anyone?? #6
We planted our food plots this past weekend. About 16 acres worth.
This is our planting process
1. Spray with Roundup in late July
2. Spray with roundup in late August and maybe add some 2,4-D to the tank
3. Plow food plots in early October. (LSU says don't plant before Sept. 20 because of potential armyworms)
4. Seed with a mix of 100 lbs of wildlife mix and 300 lbs of 17-17-17 fertilizer mixed in a spreader cart
5. Cover with a feeder house chain.
6. Pray for rain.
The feeder house chain works really good to lightly cover the seed. But this won't work in all soils. It works well in our sandy loam soil.
We get a used feeder house chain at a local combine dealer. Sometimes you can pick them up for free. We cut it to about 6' length and then put 2 lengths side by side to make it about 10-12' wide.
/ Tractorpacker anyone?? #7
I’ve used my lawn roller with good results. My harrow drag with the teeth up also does a decent job. It works just like the feeder chain.
/ Tractorpacker anyone?? #8
I know it sounds crazy, but a friend of mine just drags a pallet behind his tractor on a chain. I was amazed at how well it leveled everything, as well as incorporated the seed into the dirt. Redneck engineering at its finest. :thumbsup:
/ Tractorpacker anyone?? #9
Looks :thumbsup: ...use what you have to get the job done. :)
/ Tractorpacker anyone?? #10
I have used a pallet also. It does work well.
I've used all sorts of stuff over the years, chain link fence, old gates, cattle panels, even an old worn out box spring from a bed. So much anymore calls for a cultipacker to just assure good soil contact WITHOUT burying the seed too deep. Till I can find a cultipacker at a reasonable price I think I'll continue with the Tractorpacker method , seems to work... ok anyway..
/ Tractorpacker anyone?? #12
Now where have I read of pallets in the field? :)
/ Tractorpacker anyone?? #13
Hello fellow food plotters ive been using chain link drags for years with decent results .But I finally found an old 8 ft pull type for 400 bucks I might try to convert it to three point Its close to a mile to my food plots ,and I hate to drag it that far
Therein lies the problem with drag type attachments.. getting them to the plots. Some of my plots are through the woods, but mostly over one of my pond dams, and I don't want to drag stuff over the dam. I'll only buy 3 point stuff anymore.
6. Pray for rain.
You use 100 pounds seed and 300 pounds fertilizer for 16 acres? or is that per acre?
/ Tractorpacker anyone?? #17
I bought a cheap TSC boom pole to take care of that problem.
/ Tractorpacker anyone?? #18
I've failed to find a used culti packer on CL for years so have been using your method for years.
It seems to work ok just takes a while to do. This year I also did some of my fields going backward with my bucket down and in the float position.. we'll see how that works. Takes less time anyway...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
1995 John Deere 7400 (A60462)
1995 John Deere...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A61573)
2013 International...
Speader (A64194)
Speader (A64194)
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
