tilt bed trailer
/ tilt bed trailer #1
stevep3916
burnwell
international,johndeere
hello, I have a 20 ft. tilt bed trailer . I need to haul 863 bobcat to dealer. I have a question about balancing trailer. Trailer was bought to haul this machine and can do so with no problem. I have hauled hay, and tractors and lots of trucks and cars. Always had to load something long like extended cab truck, pull up to stops on front of bed, chain down. Now with bobcat should I balance weight just a little in front of wheels? Axles are pretty far back on this trailer, it is tongue heavy to begin with. I have never pulled skid steer before, it weighs 6,800 lbs with out bucket. Have hauled 5,000lbs hay (5 1,000 lb rolls easy enough. Pull truck is 94 ford f 250 4x4 idi turbo. thanks for your consideration.
/ tilt bed trailer #2
Bumper mount hitch you need about 10 to 15 percent of the weight on the hitch. Goose neck about 20 to 25 percent on the hitch. As far as actual location on your trailor for the load one would assume a bit in front of the axles with the center of gravity.
Several factors that makes it hard to give accurate info over the forum.
Length of trailor
Axles location on trailor
Length of bobcat and its center of gravity.
Probably forgetting something else.
Would personally prefer it to be a bit tongue heavy than to much weight on the back of the trailor. To much weight to far back and things can go bad fast if it starts to wag back and forth.
/ tilt bed trailer #3
Agree with Redlands, I tow a 10k skidsteer often on my tilt deck and typically line up the center of the skid steer over the front axle. Put just a tad more of the weight on my bumper and you only load something too far back once...
/ tilt bed trailer #4
What kind of tilt deck? If it's a gravity tilt, they pivot right between the rear axles. Makes for easy balancing. Drive forward until it tilts flat & its "ballanced". We want 10-15% tongue weight so you drive forward a little bit more passed balanced to get that.
Generally you want as much weight as close to the axle(s) as possible too. Weight at the far ends of the deck will amplify sway more than weight over the axles.
The rear part of a gravity tilt deck isnt really usable space. Weight back there is far from the axle & throws off proper hitch weight.
I liked my gravity tilt, but at 16' it was way to short. I ended up with a 22' deckover power tilt. Surprisingly not much more price wise, but the axles are further back for better balance & more usable deck space. The steeper deck angles make driving on & off a hair harder though.
/ tilt bed trailer #5
Typically I try to find the center point of weight for the object being hauled. To do that I first measure from the ground up to two points on the trailer, one at the very front of the trailer and one at the very back. As an example we will say there is 1" difference between front and back. Now load the object being hauled so it is roughly centered weight wise over the center of the axles. Take those measurements again. Move the load back or forward on the trailer until you get the 1" difference front to back. Straight above the center of the axles is the center of the load. Make a mental note of where that is for future loadings.
Once I have the center of load I measure the height from the trailer tongue to the ground. Then move the load forward until the tongue drops one to two inches, tie down the load and go. This method will give you a rough placement of the load on the trailer. If you are pulling the load very far you may need to tweak it a bit.
/ tilt bed trailer #6
If a truck scale is available close by, weight of each axle empty and then loaded will give you a much better idea of how to load it. The factors everyone is describing has to do with weight and how to balance that.
David from jax
/ tilt bed trailer #7
I think some of you guys are over thinking loading your trailers. Every trailer I have ever owned has always towed fine when it was empty. What I do is measure the height of the hitch with the trailer empty and then load the trailer with what ever load and remeasue the hitch height. When I have the load positioned so the hitch is about 3" lower its good to go. Been working for me for over 60 years. It even works fine with my new 23' tilt deck trailer.
/ tilt bed trailer #8
My new to me 16' tilting deck trailer caused a code brown on the highway taking it home from auction. I finished heading home via a friends house at 55. Shoveled maybe a 55 gallon barrels worth of snow onto the front of the trailer. The remainder of the trip was fine at 65-70.
I had my 7'x14' double axle cargo trailer do something similar after owning it for 5 odd years. Never had a problem in all those years except for one time on the highway (probably doing 70, 5 under the CO speed limit) when it started to sway. Nothing in except a hand truck & something else (a ladder maybe, I forget, but it was light as well).
Nothing makes you appreciate a good electric brake controller & knowledge of towing physics more than sway hitting out of nowhere. You never take proper loading & balance for granted after that.
I'll use bumper squat on my truck if I have to, but I always measure if I can. The first thing I did after getting my new 22' tilting deck home was load the tractor up & use my Sherline hitch scale to figure out the optimal loading placement of the machine. I measured bumper squat for future reference when I had the right weight. It was surprisingly easy to get way to much hitch weight. That was usually pretty obvious with the back if the F250 way low. Not enough wright looked fine though.
/ tilt bed trailer #9
I also have a 20' tilt. Loading it is a pretty simple task..I drive up whatever I'm loading and watch the back of the truck that's pulling it, once it drops a few inches, it's good to go.
/ tilt bed trailer #10
What kind of tilt deck? If it's a gravity tilt, they pivot right "between the rear axles"
Not sure what kind of trailer you have Fallon but my tilt bed trailer has the pivot point about 2 feet behind the rear axle. Mine has an 8 foot fixed deck in front with 15+ foot tilting rear deck.
/ tilt bed trailer #11
My old 16' & all the gravity tilts I looked at pivoted dead center between the axles. The ones with a small fixed deck in front of the tilting deck looked like they would balance better, but still had a fair amount of deck behind the axle compared to a standard fixed deck trailer. I looked at Diamond C, Big Tex & several others. Every gravity tilt I saw pivoted between the 2 axles.
I was looking at tilting decks with a small fixed front deck originally to replace the 16'. Lack of fenders & the ability to load non-tractor things from the side sent me to a deckover power tilt.
My 16' was way too short. I'm assuming it was for a skidsteer, but it was even pretty short for that. 14k of axle & a steel deck. The only way I could balance it was with the loader on the thankfully really long tongue.
/ tilt bed trailer #12
View attachment 591255View attachment 591256
I have to agree with bitternut, my 20' tilt pivots behind the rear axle. Seems to me, pivoting between the axle's would require the bed to be higher to clear the axle.
/ tilt bed trailer #13
Bingo!
I had a 20' tilt trailer for 15 years hauling dozens of different tractors and vehicles on it. When I was loading it I would let the hitch drop about 2" and it would tow perfectly every time.
/ tilt bed trailer #14
Situations like this are where I like having the built in scale on a Weigh Safe hitch. I use it when loading my Bobcat S185.
/ tilt bed trailer #15
I have a 24' quality brand 8' fixed 16' tilt and I have no problem loading a tractor with loaded tires and mower on back - I leave the loader on when we mow so there is weight up front . when loaded and ready for transport mower hangs off the back by a foot or 2 . the problem your talking about happens when you try to load a car or truck on the front tires go past pivot point - before rears come on trailer - to load a car or truck I put ramps or boards down on back of the trailer to drive onto which holds the trailer down till the tires are on it . I have not found a trailer that does everything easy - I hate dealing with ramps so the tilt is whats best for me
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
2022 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2022 Posi Track...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2019 CATERPILLAR 259D SKID STEER (A64279)
2019 CATERPILLAR...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
