JD 445 FD620D rebuild
/ JD 445 FD620D rebuild #21
Bennthere
Before you just start putting it back together, was the engine burning oil?
Can't tell from the photo, have you pull off the head? If so, now would be a good time to lap the valves.
Richard
/ JD 445 FD620D rebuild #22
Bennthere
Richard
yes the engine started burning its own oil
/ JD 445 FD620D rebuild #23
Richard001
The engine was burning no oil between oil changes.
not sure what serefli1 was referring to in the previous post quoting yours.
/ JD 445 FD620D rebuild #24
Is there a serial number or some way of telling if these motors have the plastic cam gears. Guessing they switched to metal at a certain time. Knowing that some want to be proactive and replace before major problems. Kinda sucks to pull apart only to find they have the metal already...!
/ JD 445 FD620D rebuild #25
I'm sorry
/ JD 445 FD620D rebuild #26
I'm sorry
Didn't mean anything by that.
Thinking I read once that there was a sequence in serial numbers and year of production that they went from plastic to metal gears.
If there was plastic and somebody changed them you'd have no way knowing unless they documented it in some way..
/ JD 445 FD620D rebuild #27
From what I could decipher on the s/n, the year my 425 was made was before the switch to steel cam gear.. which iirc was mid '98. Mine was s/n 419xxx so '96 model.
I made the assumption mine was still the plastic.. and I admit I did not go through the dealer to have the s/n searched to see if Deere had a record of changing this one out for steel.. I know there are records kept, but only if Deere dealer made the repair.
/ JD 445 FD620D rebuild #28
From what I could decipher on the s/n, the year my 425 was made was before the switch to steel cam gear.. which iirc was mid '68. Mine was s/n 419xxx so '66 model.
I'm interested too because I have the same motor only on a Woods Zero Turn. I'm up in the 900 hr. range..!
/ JD 445 FD620D rebuild #29
I think you meant 1998 & 1999 not '68 & '66 Were you holding your phone upside down when you replied?
/ JD 445 FD620D rebuild #30
Yea we all know if it was 68 & 66 they definitely would have been steel....! ;)
/ JD 445 FD620D rebuild #31
LOL Guess so.. mid '98 and a 1996 model is mine. tks for the correction. Will make an edit if still possible.
/ JD 445 FD620D rebuild #32
Update: Finished re-assembling this JD 425 FD620D Kawasaki and yesterday put it back in the 425. Thankful for the TBN help along the way..
/ JD 445 FD620D rebuild #33
:thumbsup: does it sound good..?
/ JD 445 FD620D rebuild #34
It sounds great thank you !!
Will keep my fingers crossed that the gaskets hold oil and hold water where appropriate. :) So far no leaks, and soon will be using it on the MC519 cart to vacuum up leaves when the ground sets up. Still some snow drifts to melt.
/ JD 445 FD620D rebuild #35
Congratulations on a job well done. If it runs, it's well done !
Richard
Kuhn FC400RG (A60462)
John Deere 4650 Tractor (A64047)
John Deere 4650...
INOP/NON-RUNNING 2007 International 4400 Day Cab Truck, VIN # 1HSMKAZN77H451431 (A61165)
INOP/NON-RUNNING...
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
25026SFL (A61569)
25026SFL (A61569)
2019 John Deere 4044M (A62177)
2019 John Deere...
