New Guy looking at a finish mower
/ New Guy looking at a finish mower #1
hiddentacocatneddih
Mahindra 485DI
Hello TBN
I have been trolling the forums while I have been looking for a tractor. I am a city type guy and my family moved out to the country of NW Tennessee last year. I had been keeping up with my 6 acres (5 is pasture) with my lawnmower that is a basket case. I saved up while shopping for a tractor. I don't believe in financing so a new machine was out of the question, although I really want an cab for the summer and winter. My main tractor requirements
1. pull at least a 6ft finish mower for the yard and 1 pasture
2. 5-6 ft rotary cutter for the big pasture unless I just finish mow it consistently
3. FEL that I can pick up motors and junk with. I have a 6BT sitting on an engine stand that is sort of trapped in my garage.... long story and its heavy.
4. Blade and groom my drive for my barn and garage along with making tracks and jump for the kids dirt bikes/4 wheelers and stuff
prefer mechanical fuel injection and virtually zero electronics (ironically electronics is my life/career). No gassers since they have an ignition and well... gas. 4wd if it is smaller size. I think manual gear trans would be nice for just cruising the pasture with a mower, but hydro is cool too.
well it happened. Last weekend I found a tractor and I am suppose to get it this weekend. A Mahindra 485di. Comes with a 5ft rotary cutter, FEL and some forks.
Any one have one?
AND the main reason for this thread..... finish mowers. I have been looking around. Some used ones locally just look like a basket case. The deal has a land pride 72" for $1250 and a frontier for $1750. They have an 84" bush hog brand one for $1750 too which is tempting.
But then RK has some around the $1750 price range brand new....
Ill have to call and see what the Kubota dealer has in stock since their website is garbage.
I want rear discharge.
Any thing under $2000 that people just swear by? or anything not pure chinesium is fine.
/ New Guy looking at a finish mower #2
Finish mowers are expensive...much more so then rotary cutters. I had Befco and Frontier RFMs and both are great. I've had a Land Pride cutter and the quality of their equipment is great. Both the Befco and Frontier were used mowers when I bought them.
So, I'd go for either the used Land Pride, Bush Hog or Frontier if they're in decent shape. If at all possible, do try them out before you plunk you're money down.
Another alternative to an RFM, especially for the pasture work, is a flail mower. There's a lengthy thread on flail mowers: https://www.tractorbynet.com/forums...l?highlight=Flail&highlight=Flail#post5312556
I looked at flails but the less is more and KISS. having a TON of knives to maintain just doesn't sound fun compared to 1-3 blades. But the cut looks awesome
If I get anything bigger than 6ft, ill have to keep my lawn mower running to do my backyard where my kids play. the gates only 6ft and change wide. Plus there isn't much room back there with the 2 swing sets, trampoline, deck and so on. So maybe taking the tractor back there wont be happening anyway
/ New Guy looking at a finish mower #4
Welcome aboard! I've been using RFM's since around 1992 and they are my first choice for mowing. With the HP you have on tap and a rear tire width of 71"? I'd want at least a 6' mower. Wider would be better. Having the deck wider than than tire tracks is desirable. How difficult would it be to modify the gate?
I've had two RFM's made by LandPride (5' and 6') and two by Caroni (5' and 7-1/2'). The 7-1/2' was bought used late last year and I haven't used it yet because I'm refurbishing it. The LandPrides are heavy decks and the quality is very good. The Caroni decks are lighter, but also do a nice job and put up with a lot of abuse. I bought the larger Caroni because of the service I've gotten from the 5 footer purchased in 1992.
Chances are with all the stuff in the backyard I'll have to keep a riding lawn mower around to get it. The gate wouldn't be hard to swap to a cattle gate or add one.
I have to keep a rider around for my ditches anyway
Really thinking towards a 7' mower since it would make it that much faster on my big flat areas.
/ New Guy looking at a finish mower #6
Before buying a finish mower, use the rotary cutter and see if you can live with the results. The advantage of a rotary cutter over a finish mower is that you can get away with mowing your pasture just a few times a year. If you get a finish mower, you need to mow every other week, depending on rain and how fast your pasture grows.
I have a rotary cutter, a finish mower and a zero turn. I enjoy mowing, but there are only so many other things to do that I mowing time needs to be managed.
The rotary cutter gives the roughest look, but compared to not cutting, it looks good enough. The finish mower is faster if I keep everything short and cut regularly, but if I go a few weeks or a month between cutting, I have to use the rotary cutter to get it under control, and then go over it the following week with the finish mower to get it back down to where I want it. But that ends up cutting it so short that it's brown for another week or so.
My current plan, and what I've done for the last few years, is to maintain my "home" area with the zero turn. That is probably close to an acre and a half, maybe a bit more. I do this every other week, but sometimes once a week if I have to. Adding a canopy over my mower has really made this a lot more comfortable during the summer heat.
About three times a year I bush hog the rest of my pasture, trails and fence line. This takes about three days, or more if I just do an few hours after work. As I add fencing and increase livestock numbers, I expect this to decrease.
I haven't used my finish mower in years, and now the tires have rotted on me and need replacing. I'm holding on to it in case I decide to use it instead of the rotary cutter after my fences are done. I'm not sure what I'll do, so it's just waiting on my to decide.
Finish mowers are great, but not as good at cutting thick, tall grass as a rotary cutter, and they will never give you as nice of a finish as a zero turn or riding mower. If you buy the tractor with the rotary cutter, I would spend my money on a better lawn mower instead of another attachment for the tractor.
/ New Guy looking at a finish mower #7
i have a small mahindra with bucket and bought a midmower unit as abackup. which i have had to use by the way. i cannot get in the smaller areas but the bigger area is done in minutes. takes longer to hook it up and unhook it than to use it. i use bucket 99+ % of the time so no need to have it on all the time. it cuts really nice and it is very nice. but i have a lawn as such and not pasture.
I cut one of my pastures, about 3/4 of an acre every week because it was over grown week. Now its all grass. I plan on maintaining it. took almost an hour. Parts of it I need to rotary cut and clean up.
my front and side yard is pretty small. about 20 minutes on a rider, wide open only 4 trees to go around really. I cut it weekly
My back yard is small, full of toys and stuff. Realistically could get done in 20 minutes with a push mower if not less if I had to but on a rider about 5-10 minutes.
I have a 1/3 acre lot I maintain that has the thickest grass I have ever seen. My 24hp rider really hated mowing it. It was some of the fastest growing I have ever seen. I may just go to rotary cutting long term on this. Tons of sticks and walnuts and pecans too.
But my big worry is my 3.5 acres pasture. It has been neglected and just had the cows maintain it for a year or more. I cut it from knee high down with my mower and it took a month or 2 with random hour here hour there. It has lots of weeds in places and the back is brush. My goal would be to cut it once to twice a month and get the grass to come in better. On my rider it takes all day even in areas that are cut down. My rider can only go 1-2 mph in the grass and is only a 50".
We use our pastures as extended yards. The big one got so bad last year with tall grass and seeds that it was obnoxious to walk around in. We are not farm people and don't plan on animals. We have toys instead so the cows will not be a permanent fixture.
A ZTR would be great. I ran them a lot when I was a kid mowing Carlyle lake Illinois campgrounds (400 acres) for the army core of engineers. But I cant justify the money right now for a one trick pony. If I had the money I would just go get a big commercial 72" ZTR and be done with it.
If my rider survives the year I would be surprised. Its a cheap troy built with 350+ hours. Decks beat to death. Motor has the valve guides ate out of it. Burns all the oil in it within 2-3 hours. Everything is wore out on it bad. But it still cuts grass. I wouldn't be offended by spending $500 on a used rider to just keep around the house.
I just figure with a 7' finish mower behind the tractor I could get all the pastures done in 1-2 hours instead of 5+. And at 1-2 hours I would do it every 8-10 days.
/ New Guy looking at a finish mower #9
Is there a reason you need a finish cut on your pasture? If not a brush cutter would handle it easier. Or a flail.
personal preference mainly. The kids and I go out and flay Frisbee and what ever else out there.
/ New Guy looking at a finish mower #11
Look at the Caroni mowers too. After a lot of research last year I couldn’t find anything bad on the brand, simple design, rugged built, decent price, and a nice cut. Really happy with mine.
/ New Guy looking at a finish mower #12
For a general yard, a brush hog leaves the grass fine. My 5' brush hog is beat to heck but leaves a pretty decent cut, only uneven because the adjuster for the right 3pt link on my tractor is rusted and adjusted crooked, haven't bothered to straighten it out... I have a 5' finish mower as well and it is about 50% faster than the 44" riding mower since the blade tip speed is better as well as 3 equal length blades instead of that stupid 13" middle blade...
As they're saying, I wouldn't have just one mower and if you do have just one a brush hog is much more versatile with a decent finish.
/ New Guy looking at a finish mower #13
If you sharpen the blades on a rotary cutter, or brush hog, you get an even nicer finish if you are just cutting pasture grass.
I thought about trying to sharpen them after I cut some of the spots that are bad.
It comes with a 5footer
The finish mower would be bigger and help with cut time and cleaner cut. The 7" bush hog brand finish mower is $1650 locally.
I pick up the tractor tomorrow !
/ New Guy looking at a finish mower #15
i use a woods RM 90 finish mower for most of the pastures. we cut every month or so. raise the mower to 8-12" keep the blades sharp and go to town. this only works when there is no brush
what it looks like after cutting
what it looks like while cutting
this was done with a 6' medium duty bush hog. it had a fair amount of brush in it
Nice. Mine is 90%+ good grass. Only a small part is brush and 2 small paddocks.
I probably will keep it 6-8 inches at most. I kept the one pasture at 3-4 inches last year or less and the grass came in nicely and the weeds all went away
/ New Guy looking at a finish mower #17
If that is $1650 for a NEW seven foot Bushhog that is a steal. I can't buy a seven foot Chinese mower for that.
My six foot Agmate has been working good for me and I bought it before the tariff increases. I think I paid $1150 after sales tax a few years back. Same mower is $1392 before tax now.
its used. looks in good shape though
i saw a new 7 footer locally for $2100. Some brand with a S at the beginning Svena? or something
Its a Sovema brand 7" finish mower for $2100. It looks nice, rear discharge. The savings on the used one tho has me seriously looking at that. I have to buy a box blade too but i am thinking about the RK brand blade 7 footer.
Got the tractor to the house.
Do you normally have to adjust the 3 point height as you go over hills with a bush hog a little bit?
The top link swivel is welded solid on it. Previous owner mowed some extreme banks and used it as a wheeler bar in case he bounced while climbing.
Looks like this forum hosts images so I'll get a picture
Out here in west Tennessee we have had a ton of rain and the ground is really soft. Bought got stuck at the bottom of a hill
