How well does the L2501 steer with a load on the loader?
   / How well does the L2501 steer with a load on the loader? #11
Properly counterbalanced it should be fine. It shouldn't be operated without a proper counterbalance as tempting as it may be. Not only is it dangerous, but it puts a lot of stress on the front axle components.
   / How well does the L2501 steer with a load on the loader? #12
They're thinking about loaded R1's instead of loaded R4's, you can put 3 sets of wheel weights on the R1's and by my calculations that will add 220# of weight to the rear over the R4's.
If you are not into routine max FEL loads, this should be fine.
R1/ag tires are four ply and flexible relative to R4s.
R4/industrial tires are six ply therefore have stouter sidewalls than R1 tires.
R4s front tires support heavy loader loads better as they do not squat like flexible sidewall R1/ag tires.
With R1/ag tires you will not be able to mow over turf without rutting. I realize you have not mentioned mowing turf as a need.
Three Point Hitch counterbalance, all behind the rear axle, is much more effective as counterbalance balance pound for pound, relative to loading the rear tires.
Tradeoffs. Always tradeoffs.
   / How well does the L2501 steer with a load on the loader? #14
This was only a test. What we had asked for was something that weighed around 600-700# for a test, not over 1400#.
As I said it was a fine machine. The weak spot was just weight & ballast. My new L4060 with the middle sized loader has its weak spot on hydraulics. It stops lifting but is extremely stable even with nothing on the 3pt (which I only did once).
It course those are only the obvious weak points. It could be axle strength as well on both machines. Every system will have a weak spot. If you need that up, something else becomes the weak spot. It's just a matter of knowing where the limitations & weak spots are then working around them.
With loaded rears a 5' rotary cutter & about 200lbs of stuff piled on the back of the rotary cutter it still wasnt super stable helping a neighbor move some allegedly 1,200lbs hay bales. That was probably past the smart operating capacity of the machine.
   / How well does the L2501 steer with a load on the loader? #15
Economy Ls are very unsafe without proper ballast on the 3pt when using the loader. My former L3200 (same frame & weight as a L2501, L3301 or L3901) could pull the back end off the ground with loaded tires & heavy 3pt ballast. Fine machine, but the loader is stronger than the machine can readily be ballasted.
I concur with this.
   / How well does the L2501 steer with a load on the loader? #16
R4 tires, loaded, 670 lb box blade, maxed out load of wet dirt in the bucket (would only lift to grille height), and I have never noticed any additional steering effort.
The thought never crossed my mind.
Of course I did not try to turn the wheels while sitting still because that is not a normal operation.
I was moving dirt half mile down a logging road.
   / How well does the L2501 steer with a load on the loader? #17
The standard Ls are light machines. I don't even really like to road mine without a weight on the 3PT to offset the loader. I also have beet juice in the tires(first person to have it done by my dealer).
   / How well does the L2501 steer with a load on the loader? #18
No issues here with steering at ALL
   / How well does the L2501 steer with a load on the loader? #19
Really? Geez, somehow I manged to mow this 30 acre capped landfill on R1 ag tires and it doesn't look rutted up to me.
   / How well does the L2501 steer with a load on the loader? #20
Pretty sure he is talking about a weekly finish mow around the homestead.
Fields and pastures rough mowed once a quarter would not be an issue.
Driving over manicured turf once a week, you would definitely notice the aggressive tread lugs on the soil.
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2005 CATERPILLAR 906 WHEEL LOADER (A52709)
2005 CATERPILLAR...
Stanley hydraulic power pack (A56435)
Stanley hydraulic...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
PALLETS OF HEAVYEQUIPMENT (A58216)
PALLETS OF...
