What is this 3pt attachment?
/ What is this 3pt attachment? #1
robbyr
Elite Member
western east central texas
ford and mahindra
Saw this today. Don’t think I’ve ever seen one before. Looks like quick attach levers but what for? The bottom of the pic is hood of my truck.
/ What is this 3pt attachment? #2
I use it for a snow shovel,,,
:laughing:
Mine came from Harbor Freight for $77,,,
/ What is this 3pt attachment? #3
Looks like a standard 3 pt quick hitch to me.
What am I missing here?
/ What is this 3pt attachment? #5
Land pride quick hitch
/ What is this 3pt attachment? #6
what are the cons of using quick hitch
/ What is this 3pt attachment? #7
The height and width of all attachments are not equal and the quick attach isn’t adjustable......most don’t or can’t use them.
/ What is this 3pt attachment? #9
Quick hidge come standard for tracktor hp and so the implements that is build for that hp.
If you have the correct implements it can be setup and after that you will be able to attach you impl quickly
/ What is this 3pt attachment? #11
Finding out some of your PTO shafts are too short to use with the QH
You can use an extension for that. Run one on my brush cutter.
You do have to be mindful of the driveshaft to hitch clearance. Let the 3pt down too far and shaft will rub in the hitch.
/ What is this 3pt attachment? #12
To the OP's question.....in a perfect world, this attachment allows the tractor to quickly hook onto a implement just by lifting onto the 3 pins. No more getting off the tractor, lining up the arms, installing pins, and installing clips. In a perfect world..........
I got a new tractor in October with the quick attach on the loader. Bucket, grapple, hay fork. No more trying to line up four holes to beat the pins in. I just have never seen it on 3pt. A few years ago I remember reading about Pat’s quick hitch but have heard nothing about it since. On my new Mahindra there is an attachment on the two lift arms that allow it to slide out a little further making it easier to hook up to 3pt implements.
/ What is this 3pt attachment? #14
I purchased my 3032E with the JD I-Match at the dealers recommendation. I cant imagine not having it. I can be hooked up and gone in a couple of minutes.
/ What is this 3pt attachment? #15
I too have the slide out lower lifting arms. I only had a box blade, now I have a tiller and a scraper. I'm wondering how much trouble I'm going to have switching. before my back surgery Ihad a smaller tractor with smaller implements.
/ What is this 3pt attachment? #16
Loader quick attach is different concept from 3 point quick hitch. I don't know how many of us have 3 point quick hitches, but it's a lot.
/ What is this 3pt attachment? #17
I looked at one but only one attacment would fit and don't want to modify everything else.
/ What is this 3pt attachment? #18
My 3pth arms are too short, and I've been trying to decide whether I should buy one of those or simply replace the arms. The real irony though is that one reason I replaced my L275 was because those same arms were pretty much worn out.
/ What is this 3pt attachment? #19
Just keep in mind if you add the quick attach 3 PT you also have to have the implement set up also with the correct attachment pins. So it's not just buy the quick hitch, a little more to it than that.
SCHEDULE 80 PIPING ON PALLET (A67714)
SCHEDULE 80 PIPING...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
2009 CHEVROLET IMPALA CAR (A66091)
2009 CHEVROLET...
