Used chipper prices?
/ Used chipper prices? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Any idea what a used 3pt chipper in nice condition might cost? I've got a lot of mature evergreen bottom branches to cut and chip and a 3 pt chipper would be the right tool to use. No risk from a burn pile fire near the house and I can proceed at my pace rather than a rush job with a rental engine driven chipper.
I have owned a chipper before that it took up to 3" and was self feed. I forget the name but sold it because it was too slow and sometimes bound up with smaller pieces. So, I'm thinking 4" or so with a larger sized unit better able to take wood faster even though I would mostly do 2" branches. Any ideas what a used one would go for and preferred brands? Thanks in advance. :dog:
/ Used chipper prices? #2
A couple years ago I found a lightly used 4" Wallinstien gravity feed on Craig's list, I paid 1100.00 for it.
How did you find the gravity feed worked?
/ Used chipper prices? #4
I had a gravity feed Wallenstein too. The gravity feed worked fine.
There are two classes of chippers, those that chip primarily 2"+ material and chipper/shredders that shred leaves and branches. One chipper will not do both tasks well.
The problems with chippers are two: clogs and maintenance. Clogs have to do with above.
Maintenance has to do with maintaining blades sharp. PTO chippers have from one to four blades. Better chippers have four. The blades need to be removed periodically from the heavy drum, which is difficult, then sharpened precisely, perhaps 12" of edge for four blades, then reinstalled and adjusted. (Sharpening requires precision. There are several services that sharpen vis US mail or a machine shop can do the sharpening and honing.)
THIS IS A LOT OF WORK.
In your favor you anticipate chipping a single type of wood. Chipping mixed hardwood and softwood leads to many more stoppages because optimal blade adjustment differs for hardwoods and softwoods.
Good luck.
I sold my Wallenstein because I found burning trimmings and BUYING mulch was better use of my time.
If you decide to proceed buy the largest intake capacity chipper you can afford.
/ Used chipper prices? #5
new guy here, I have looked at chippers and have come to the conclusion that renting a big unit for a weekend is cheaper and you can feed a lot of branches thru a bigger chipper.
/ Used chipper prices? #6
That would be good and I reserved a Brush Bandit rental with the rental cost applicable to a purchase...
Show up to pick up the rental and the guys have me hitched up and get the safety demo...
Just about to leave and the counter guy says he forgot to get a copy of my contractor license???
I'm not a contractor, only property maintenance and Christmas Tree Farm in the family...
Stops everything... they have a huddle and say they can sell me one but unfortunately not rent me one due to liability...
Yes... I was seriously considering buying it for the business.
We do have a feed 3 point that is working well.
/ Used chipper prices? #7
I've had a gravity feed Bear Cat for over 10 years. It works very well for me. People who do chipping for a living need mechanical feed, but for most of us it's a waste of money and maintenance effort. Gravity feed takes longer, but if you are only using it a few times a year to clean up newly-gathered brush it's perfect.
There are two classes of chippers, those that chip primarily 2"+ material and chippers that shred leaves and branches. One chipper will not do both tasks well.
I don't know what you mean by two classes of chippers. Chippers don't do very well with leaves and small (under half inch) brush. That's what shredders are for. If you need to do a lot of small stuff you need a chipper/shredder. If you only do a little of that a chipper will do.
I've never had a clog in my chipper in all the time I've owned it.
Removing the blades isn't difficult if you buy one that offers reasonable access to the flywheel. My Bear Cat requires me to remove one bolt and swing the output chute to the side. The blades are then exposed and then can easily be removed with a socket wrench. The only "difficulty" is I sometimes have to dig out the dirt or whatever that collects around the head of the bold with a small screwdriver.
My old chipper/shredder was a pain to sharpen the blades. You had to take off the top of the shredder chute to access the blades. There were lots of bolts, some hidden behind the belt guards, and the part you had to take off was heavy and awkward enough to be pain to remove.
The blades do have to be very sharp to self-feed. They still feel sharp to the touch when they are too dull to self-feed. I have a Tormek wet sharpening system that holds them at a fixed angle that makes sharpening easy. My blades, like many, are sharpened on both sides, so you only have to sharpen them every other time; in between just turn them around.
Getting one with a blower is really worthwhile. My first chipper/shredder didn't have one and I had to stop and clear the chips out from under it every few minutes. A blower also helps when using it to do spring cleanup of fallen branches - just point the chute at the woods and let the chips fall where they may.
Having one handy of occasionally work throughout the year is the best reason to own rather than rent one in my view.
/ Used chipper prices? #9
Thanks... Mom is always one to pitch in and always finding something that needs doing... she chipped all the unsold trees... all I did was move the tractor around.
She loves spending time at the tree farm... being able to help is very important to her plus her growing up on a family Diary farm likes being around the cows, pigs, chickens, horses... well they never had horses on the farm...
After shopping for used units my brother opted to go with the 3-point with feed based on favorable TBN comments...
When it arrived the knives were way out of spec... dialed them in and unit has been working well the last two seasons... so no long term report. Another plus is not having another motor to maintain...
Mom ran her last full marathon at age 75...
You can tell she keeps active. How old is she in the photo?
/ Used chipper prices? #11
84... soon to be 85
Things would be perfect if it was not for Alzheimer's
/ Used chipper prices? #12
Honestly, I was a bit unimpressed it. I found that it was slow, and it clogged with pine needles if chipping pine. I used it 2-3 times and now just pick stuff ups with the grapple and build a burn pile instead of chipping.
/ Used chipper prices? #13
I've had both gravity feed and hydraulic feed. I would not go back to gravity feed. I have a Woodmaxx 8H hydraulic feed chippper with 50 hours on it.
With gravity feed I have to tilt the material way up in the air to get it in the chute. That's a lot of extra work with long material. The gravity feed chippers don't feed well all the time. I spent a lot more time trying to get stuff in at the just right angle to get it to feed. With the 8H it usually just goes. The gravity feed is really self-feeding. When it gets going it grabs the material and sucks it in at high speed. That can be dangerous if you're not paying attention. The power feed goes at a measured rate, and there's a safety to stop it. You can't stop a self-feeding chipper once it's gotten going on a large branch. If you got your hand caught in that branch you're in trouble. It never happened to me but I was really careful.
The only extra maintenance on the 8H's power feed has been a couple more zerks to grease and checking the hydraulic fluid level a few times.
I like having my own chipper so I can go do an hour or two's work when I have time. It takes at least two hours to go to town, pick up a rental thing, and drop it off when I'm done. I can get the tractor with chipper on the back into places that I can't back a trailer into.
/ Used chipper prices? #14
^^^Pretty much sums up my experience except Wood Max 9900
/ Used chipper prices? #15
I bought a new wood maxx 8H last year for $3000 delivered. 8" hydraulic feed. I don't use it lots but for that money I didn't want to screw around with a used one.
/ Used chipper prices? #16
I with you on that.
When I maintained our 3 acre apple orchard I always rented a commercial chipper. We always had the trees pruned with all the butt ends laying in the same direction before I rented the chipper. Chipped ever thing in a single weekend without being hurried to finish because all the time was spent chipping, not cutting and pruning limbs at the same time as we went down the rows. Evergreen branches would be a breeze to handle the same way.
The advantage of the rental unit was a much bigger machine than I could ever afford, along with a very large throat and power feed. That machine ate branches faster than my wife and I could feed it. Repeated that every 4 years or so for quite some time.
To the O.P., whether you rent or buy your own, I wouldn't be without a power feed. ;)
/ Used chipper prices? #17
You guys are able rent full on commercial machines without restriction?
/ Used chipper prices? #18
In my area, we can. Well, at least the size I always rented. They had a capacity to take anything up to 8" in diameter. Don't remember the H.P. That may be on the lower end of a commercial series chipper. And lucky for me, the rental place is only 12 miles away.
/ Used chipper prices? #19
The one I was looking at and reserved was a 12 inch... but the Dealer said they couldn't rent me the 8 inch either...
I know they rent to the city public works and I doubt the city has a contractors license...
Anyway... saved myself thousands...
/ Used chipper prices? #20
I looked for a year or more for a used chipper and barely found anything at any price.
I bought a Woodland Mills chipper with 8" hydraulic feed. I have about 30 hours on it and it has worked well. I have chipped black oak (LOTS), pine, and cedar. The only thing it didnt like was pin oak-- that is a difficult thing to handle let alone chip. But I slowed the hydraulic input speed down and it ate all the pin oak limbs without problem.
HARDEE 5' ROTARY MOWER (A63291)
HARDEE 5' ROTARY...
SDLD25 Crawler Dumper (A64047)
SDLD25 Crawler...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
1999 GMC C7500 Truck, VIN # 1GDL7H1C8XJ515294 (A61573)
1999 GMC C7500...
Gehl RS5-19 (A62177)
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
