2020 GMC Sierra HD
/ 2020 GMC Sierra HD #61
They don't have it wrong, but HP is still what does the work. Having more torque just means the HP is accessible at a lower RPM, which is nice for calmer driving, engine longevity, and fuel consumption, among other reasons. Diesel engines lend themselves to power at lower RPM, which means high torque figures. But truck fleet operators don't choose diesel engines for the torque rating.
Actually Torque does work, HP is just a theoretical figure on how fast the work can be done. Torque is measured, HP is calculated.
/ 2020 GMC Sierra HD #62
What I like about the new GM trucks, is they are just plain. They "look" like just a truck. The interior is blain, and nurtural. The radio is very basic and simple. None of the technical mumbo jumbo, like the RAM or Ford. Just a simple plain radio. And the radio sound system is very basic. Ford and RAM put speakers EVERYWHERE, where GM just puts a few. Why have so many speakers? The dash is also VERY basic, when compared to RAM and Ford. GM, realizes the "general" driver doesn't care about wiz bang dash. RAM and Ford, they went way overkill on the dash, just too much info and adjustment options.
This is in the high trim levels.
Then, we have the mechanicals. GM is NOT playing the power game. They are keeping the numbers realistic. Who NEEDS 1000# of torque? That is just insane. And GM keeps its tow ratings very low, that is good.
GM top level trim trucks are, well, very basic and simple when compared to Ford and RAM. Its kinda old school. Considering its mostly older men that buy large HD trucks, GM is the way to go. Its like owning an old simple flip phone. So, an older person can feel comfortable driving.
/ 2020 GMC Sierra HD #63
I found your post rather odd... First of all, higher trim levels in a Silverado are just as nice as anyones, but I agree, lower trim levels are more basic, which I like. They come with a basic radio, but the higher trim offer anything any one else has, full carpet, more speakers, wireless charging on the console, full nav system, back up camera, ect. ect..
One thing I will say, the radio/screen is MUCH less cluttered on the GM, compared to ford or ram... BUT, I think ford and ram can be bought in lower trim levels too, you just don't see them much...
As for torque, the GM diesel has over 900 pounds torque, near 1000 pounds, so I'm lost on your post.
BTW, I really like my new Silverado and it does have the lower trim level that I like...
SR
/ 2020 GMC Sierra HD #64
Diesels, four strikes in particular can not rev because the cam duration is so short .
Diesel's have a lower RPM because the pistons have a longer stroke. The speed the piston travels is still equivalent to higher revving shorter stroke engines. The longer stroke increases the output torque by taking advantage of the combustion characteristics of diesel fuel.
/ 2020 GMC Sierra HD #65
I realize aesthetics are subjective but go look at the interiors of a RAM and a Ford pickup and then back to a GM pickup and see if you still think GM's pickup interiors are as nice as RAM or Ford. GM isn't playing their best game when it comes to interior and hasn't for sometime.
/ 2020 GMC Sierra HD #66
I found your post rather odd... [SNIP]
Exactly, the 2019 Chevrolet 3500 Diesel has 445HP, 910# of torque and a max GCWR of 31100# (per: Silverado 35HD for Sale: 219 Silverado 35HD Pricing | Chevrolet ) vs Ford's 450HP, 935# of torque and 40,000GCWR (per: 219 Ford(R) Super Duty Truck | Powerful Features | Ford.com ) and Ram's 385HP, 930# of torque and 39,100# GCWR (per: 218 Ram Trucks 35 - Powertrain Engines ).
Aaron Z
/ 2020 GMC Sierra HD #67
My brother has a NEW Ram, My buddy has a NEW Ford and I have a NEW Chevy, so I not only have looked at all three, I've spent time in all three...
I just don't knowing what you are, or aren't seeing? Given the same trim levels, all three are similar inside...
BTW, right now I own all three brands of trucks, so I've been living with all three brands for quite a while...
SR
/ 2020 GMC Sierra HD #68
SR
You got a favorite?
/ 2020 GMC Sierra HD #69
You got a favorite?
Yes, the brand that has given me "by far" the least problems as they get older...
Your first clue is, it says Silverado on it...
Don't even get me started on the other two money pits!!
SR
/ 2020 GMC Sierra HD #70
In my rural farming/ranching community HD trucks earn their spot in the driveway. It' Dodge, then Ford very close behind, then a gigantic leap to GM third.
It seems the chassis is what separates GM.
/ 2020 GMC Sierra HD #71
Very well stated.
/ 2020 GMC Sierra HD #72
Yes, this. When you say "the combustion characteristics of diesel fuel" I am guessing what you mean is that diesel is a slower burn that provides expansion gases through a longer portion of the stroke. It is like comparing a smaller number of long pushes, to a higher number of fast pokes. Quickly poking something light can get it moving fast, but the long push does a better job of getting a heavy weight up a hill at a steady speed.
/ 2020 GMC Sierra HD #73
Put your high torque 200HP engine on a generator and a moderate torque higher rpm 300HP engine on a generator . Tell us which can carry a higher Kw load ?
/ 2020 GMC Sierra HD #74
Why not tell us and the reason why?
/ 2020 GMC Sierra HD #75
Long strokes small bore designs ç*¥nder square are used on diesels as it is easier to obtain a high compression ratio . Short stroke , large bore designs are used for lower compression and higher rpm applications .
The larger bore also allows larger valves for improved high rpm airflow .
Per cubic inch displacement and same compression ratio . Under square and over square engines make the same power .
The larger surface area of the piston makes up for the reduced leverage of a shorter stroke .
/ 2020 GMC Sierra HD #76
You mean before they melt? Cars and light trucks aren’t a continuous duty hp rating. And unless you have a gear box to get the high rpm motor in the power band the 200 hp motor will win.
/ 2020 GMC Sierra HD #78
Serious or just pulling my leg ?
Do you know any high school physics teachers ? Show them the statement .
Melt ?
/ 2020 GMC Sierra HD #79
If you do not understand now , pages of further explaination will not make any difference . Could also be you are just playing games and don’t want to know .
How am I playing games? You make a claim, I asked you to substantiate it. It's not my responsibility to provide the support for your claims.
I've spent a lot of time working on engine designs and operating dyno's, if you dont agree with what I stated about torque/hp that's fine but nothing I said was false, go ahead and research it. And no I'm not here to get into a pissing match about it.
Since you like examples I can point you to a old 4cyl 2stroke diesel that operated a generator that powered a town, I'd have to find the electrical specs but the engine output was 300hp @ 300rpm giving it a torque output of 5,252ftlbs. Pretty sure the electrical output is higher then a 350hp 5-600ftlb genset.
As for engine designs, we could go all day about bore/stroke/piston speed/piston acceleration/VE/flame propagation etc. but I dont think this is the right thread to go down that path.
Plus typing all this on the phone isnt easy.
/ 2020 GMC Sierra HD #80
Melt ?
Serious. How long do you think a car or light truck engine will run under continuous load at rated hp? I’m betting not very long and I’m betting overheating is the first point of failure. What does the high school physics teacher have to do with it?
2022 Belshe WB14 18ft Trailer (A64047)
2022 Belshe WB14...
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
