Crossover relief
/ Crossover relief #2
That’s exactly what I put on mine. A few hoses and adapters (maybe) and it was good to go. I think it took 1/4” bolts to mount it.
/ Crossover relief #4
Yes, that is what you need, note we also sell a similar one.
/ Crossover relief #5
I used the one with 3/4" ports only because I could get a better deal on it at the time and I needed to add bushings anyway since the hoses from the 3rd function were 3/8" and the hoses to the plow are 1/4".
Little tip, I mounted my crossover relief to the plow instead of to the QA plate so that all of the hoses stay with the plow making it easier if you ever need to unhitch the plow from the QA plate.
/ Crossover relief
Do you have a pic of how your plow hooks to your quick attach plate?
/ Crossover relief #7
Would this type of valve be used in the event of hitting something on one side of the plow letting it relive to keep things from breaking ?
/ Crossover relief #8
Yes, that is correct.
/ Crossover relief
Nice. Thanks.
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2020 International LT625 Sleeper 48 (A62613)
2020 International...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2019 FREIGHTLINER CASCADIA 6X4 TANDEM AXLE SLEEPER TRACTOR (A59909)
2019 FREIGHTLINER...
