Polar Vortex Preparations
/ Polar Vortex Preparations #1
TheMan419
Indiana
New Holland Boomer 24
So we are supposed to get negative 20 actual air temps as a low Wed Night/Thursday Morning. I will add Power Service Anti Gel (White bottle right?) and have some 911 on hand. I do not plan on starting the tractor Wed or Thursday.
By Friday we should be back up to 22 above zero. So life will be good again.
Anything else last minute to do? Tractor lives in an unheated barn. Barn also stores about 700 bales of hay so it remains "warm".
/ Polar Vortex Preparations #2
I don’t trust the stuff right from the pumps so always treat mine with an anti gel additive as well I use optilube XPD and have never had the need for the 911 bottle I keep on hand.
/ Polar Vortex Preparations #3
If you don't plan on trying to start it before the weather warms up, why do all the treatments?
/ Polar Vortex Preparations #4
Your water pipes are in greater danger than your tractor! Just wait until the weather heats up - and leave it alone!
/ Polar Vortex Preparations #5
My truck is diesel. It was -13 when I started it up this morning. No issues with the pump fuel
I’ve never had any trouble with gas station diesel jelling
/ Polar Vortex Preparations #6
It's always best to plan ahead and be prepared in the event of an emergency should the tractor be needed at any time.
To the O.P., I have never had a need to use 911, however I have heard from my neighbor that it really works well.
Ya never know when an emergency might strike. Want to be prepared.
We are supposed to get 5 inches snow today. I値l clear the drive tonight. Then park the tractor and expect not to run it until Friday. But I want to be prepared.
We are supposed to have historic cold temps. A low of -20 actual air temp.
/ Polar Vortex Preparations #9
It's been colder than -20F several times here. 1984, 1985, 1994. Seems it's always the third week of January. In 1994 we had a cabin rented at Potato Creek and it hit -22 out there. We went ice fishing. It was nice. Caught a couple dozen 11" perch. But after an hour or so of sitting on an upside down bucket (no tent or shanty) my father-in-law couldn't take it anymore, so we left. I went out several times that week and had the place to myself. :thumbsup:
/ Polar Vortex Preparations #10
I'd say the A'freeze would be a bigger concern than fuel. Things can bust that you might not know about right away.
/ Polar Vortex Preparations #11
Yummy..Perch.
Used to test the antifreeze at the start of winter, but not anymore as it doesn't get very cold on the coast side of Washington state.
/ Polar Vortex Preparations #12
The only machine I have that I'm concerned about the anti-freeze in is my '93 Suburban. It had a radiator hose blow this summer. Forgot if I checked the antifreeze level after I repaired and refilled it. I'm sure I did, but gotta check again, just to be sure.
My PowerTrac Pt425 is an air cooled Kohler, so I just keep a battery tender on that all winter, and use a battery booster and a shot of carb cleaner when I need to start it below about 5F.
/ Polar Vortex Preparations #13
We buy a lot of off road diesel and we are careful to treat the fuel in the tank on the equipment that is not used as much. I typically add the anti-gel in the fall before the switch to the winter blend. Once we are in the winter blend we don't worry. Nothing worse than getting caught with summer blend fuel in your equipment. You'll only make the mistake once.
/ Polar Vortex Preparations #15
I moved my 2.5 gallon water fire extinguisher, handy wipes and a couple of fizz cans from the tin shed into the heated garage, just in case the tin shed freezes. It's been below 40 degrees inside 3 times so far this winter and today will probably be the 4th time, unless the sun comes out.
Good news, the sun came out. 40.9 degrees inside the tin shed. Woo Hoo!!
/ Polar Vortex Preparations #16
I致e never had any trouble with gas station diesel jelling
Where are you located?
Add that to your profile so your comments can be quantified
/ Polar Vortex Preparations #17
Last year I had my fuel gel in my BX. It wasn't as cold as its suppose to get this week either. "Should" have been winter fuel also but you wonder, I also had added Howes to it and it still gelled. I've also suspected I had the fuel gell a couple of other times but had the original little fuel filters on my BX at the time and it was hard to tell for sure.
/ Polar Vortex Preparations #18
Same here. I always keep a couple full 5g cans on hand and rotate them so it's possible to have summer blend still in the winter. I put Power Service in 'em when I fill them, no problems yet (knocking on wood).
I'll go out on a limb and guess that your truck gets used regularly so it's likely the fuel is fresh and seasonal. If your tractor doesn't get used much it could still have last fall's fuel in it.
/ Polar Vortex Preparations #19
My truck does get used everyday but the post I responded to wasn't regarding stored or old fuel. The poster said they didn't trust diesel that came out of the pump and always added anti gel
That is a waste of time IMO unless you are treating summer blend
/ Polar Vortex Preparations #20
Sure sucks though huh!!!
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 FREIGHTLINER...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
1998 TRAIL KING TK70HT HYDRAULIC TAIL TRAILER (A67714)
1998 TRAIL KING...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
