Bucket mounted on pallet forks - am I crazy?
   / Bucket mounted on pallet forks - am I crazy? #1
KiwiBro
Gold Member
New Zealand
Kioti RX7620
I work alone. On firewood duties I like to scoop up a bucket full of rounds and raise them to the wood splitter height so to avoid lifting rounds onto the splitter table. But, there are too many times during the course of the day I need the pallet forks and it gets old swapping between the two.
I'm wondering about cuttin slots in the back of the bucket and welding fork/tine sleeves to the top side of the bottom of the bucket. I can use the log grab of the forks to hold the bucket from falling off the tines when tipping the bucket.
Good/bad idea? Any issues you can see with it?
   / Bucket mounted on pallet forks - am I crazy? #2
Why am I reminded of a Wile E. Coyote 'documentary'... :scratchchin:
There you go, we have a name for it. The ACME bucket.
   / Bucket mounted on pallet forks - am I crazy? #4
What about clamp on bucket forks?
   / Bucket mounted on pallet forks - am I crazy? #5
Would a set of forks for the three point hitch do the job?
   / Bucket mounted on pallet forks - am I crazy? #6
What are you lifting with the forks all the time?
   / Bucket mounted on pallet forks - am I crazy? #7
Google forklift tilt bucket. We use them at work with 2 or 3 yard hoppers. Would work well for firewood.
   / Bucket mounted on pallet forks - am I crazy? #8
That, or build a "box" that fits on the forks. Then you can roll wood into the box, or set it down and use the pallet forks to push rounds into it.
Another idea might be to make your quick hitch a powered one (with a cylinder or electric actuator). Then you can change attachments without leaving the seat.
Aaron Z
   / Bucket mounted on pallet forks - am I crazy? #9
I don't think forks are going to help you if you are moving fireplace length cuts... Only time I can see a set of forks is good as if your log lengths are longer than your bucket is wide..... IF you keep swapping between bucket and forks during day you are not working efficiently.... Yes forks may be useful but do all your fork work first thing and get everything cut to length then swap to bucket work.... I really think the above box idea is good if your already have wood at fireplace lengths....
Dale
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV6NPNJ0431, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
Water Line Hose (A59076)
Water Line Hose...
