joeu235
- Joined
- Mar 27, 2014
- Messages
- 724
- Location
- Little River, TX
- Tractor
- John Deere 4020 / 6403 / 317 Ford 5600
bigger diesel tractors won't start off a gas truck because there aren't enough amps available.
Watch what you wish for!Wow lots of professional jump start experts on here. Can anybody hold a seminar on the proper use of toilet paper, lolol!
Perhaps this is a starter for a new topic, but I wasn't aware you could pull start a tractor with a hydrostatic transmission or even tow it for that matter without disengaging the HST somehow.
Yet another benefit of having a gear transmission. Not meaning to start a fire, just had to get one more whack on that dead horse!
TERRIBLE ADVICE!!!
This has killed many many people.
I have lost two friends from this dangerous mistake.
And no, it was not because they were idiots. One of them actually was a very talented millwright.
His grandson was seated on the tractor, he connected the cable to the starter and the tractor ran over him.
If you think you above making a mistake like he did; fine.
But do you think it wise to give this advice out to every Tom, Dick and Harry that reads this forum?
Are you sure they understand the hidden danger?
DON"T CONNECT YOUR JUMPER CABLES TO THE STARTER!!!
Apparently they can stick closed if you wear the battery down too far.I have no idea how you could get killed connecting a cable to the starter, unless the contacts in the starter solenoid were welded shut. I'm guessing what you are thinking of is shorting the solenoid to the battery cable on the starter to start the tractor and the tractor was in gear.
After a search there is no consensus as to the correct way, other than always make the last ground connection away from the battery.
Learned the way I do it from my Dad (auto mechanic for 20 years and then full time farmer) and I'm sure he learned it from his Dad who
was also a mechanic and also had the John Deere dealership. And yes, I've seen both of them jump across the solenoid to start a tractor
from the ground, after making sure the tractor was in neutral. I don't do that.
We had a copper strap attached to the battery cable at the tractor starter on a couple of tractors to making jumping easier when it was really cold
and livestock had to be fed. Good thing we didn't know the gas pickup wouldn't be able to jump the tractor!
Apparently they can stick closed if you wear the battery down too far..
My tractor (TYM 554) won稚 start and I知 suspecting a dead battery. Can I jump start it with my truck (Ram 1500)? I don稚 want to cause any damage to either vehicle.
