Homemade Tracked mini dumper
/ Homemade Tracked mini dumper #21
How did you cut the tires? I've never had any luck cutting tires.
/ Homemade Tracked mini dumper #22
Interesting, am also in early stages of building one.
I plan on using a walk behind snowblower as the traction as it provides varied speeds and build up the front framework with a wide full swiveling wheel or maybe even 2 full swivel.
It will be side dumping.
I have feelers out for a discarded blower frame and one friend said to take the one he was about to haul off to the scrapper.
Problem is that it took me all of 1/2 hour to do a complete tune up/ repair and I now own a 13HP 33" MTD c/w electric start that looks like new and starts 1st pull.
Ideally what I wanted was an old Ariens, 24" w/o motor as I have a few in my project pile.
For power anything in 3-5 hp is all that I'd need and that I have.
Another neat candidate was a discarded electric golf cart that I am still contemplating.
Also have access to a discarded electric wheelchair that could become a suitable doner .(if I decide to go electric)
/ Homemade Tracked mini dumper #26
Welcome back and thanks for the update. Is there anything that holds the track on? I would be concerned with it walking off with no center sprocket. Keep up the great work! One thing in the video, it's just weird to me seeing the piece move and the drill bit not spinning...LOL
20190103_144905.jpg 20190125_110320.jpg 20190124_111544.jpg 20190124_095054.jpg20190124_092708.jpg 20190117_124338.jpg 20190105_190112.jpg 20190103_150628.jpg
Fixing bearings. The next step will be the manufacture of brake support
20190129_143333.jpg 20190129_143439.jpg 20190129_155246.jpg 20190129_155625.jpg
/ Homemade Tracked mini dumper #35
Looking good, lots of progress :thumbsup:.
/ Homemade Tracked mini dumper #36
a little convex shape on the wheels would keep the track on, that's what is used on old machinery that use a flat leather belt, works great..
Hi. I start all over again. The transmission will be 100% new. I gave up the differential, I use two clutches for onboard turning.
20200409_094354.jpg 20200401_144629.jpg 20200402_140514.jpg 20200401_172557.jpg 20200409_093952.jpg 20200409_090040.jpg 20200409_085236.jpg 20200402_140555.jpg 20200409_094122.jpg 20200401_165005.jpg
8ft Fork Extensions (A64553)
8ft Fork...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
JOHNSON 1R POTATO HARVESTER (A64278)
JOHNSON 1R POTATO...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2017 Mack Semi (A64047)
2017 Mack Semi...
