Loader for YM155d
/ Loader for YM155d #1
Jtullis13
Arlington, Ne
Yanmar YM2210D & YM 155D
Ok guys I have been contemplating getting a loader for my 155d, but I have a few questions/concerns. First off I tried to call Coldwater and there was no answer, so does anyone know if they are still in business? I was going to get a quote on a loader from them and also ask him the same question I am asking you guys. What do I do since I don't have that adapter plate by my shifter for the hydraulic lines? See attached picture it has the R,1,2,3 labeled on it. The 155d's that I have seen have that adapter plate to plumb the hydraulic lines and I am not sure if Coldwater has something for this or if I can bypass that plate and use different ports on my tractor.
Any help would be appreciated.
/ Loader for YM155d
Have you considered Koyker?
I have considered Koyker, but I was just wondering what Coldwater's price would be too. That way I would have a comparison between the 2 of them. I have a Koyker on my 2210d and its very nice, was just looking for other options.
/ Loader for YM155d
Winston I was looking at that diagram from Hoye prior to my post and I my brain must not have processed the diagram flow chart correctly. I haven't seen a 155d with a loader up close or know the correct hydraulic flow with a loader attached. I just know that the block in the picture that I posted is for a 155d with a loader is how they route the hydraulic lines, so I didn't think that adding the adapter from Hoye at the pump would change the flow, but now that I am looking at it again I think it would work. I just kept thinking that I needed that original block in the picture for a loader to work was all. I would also want PB for the setup so I need to consider that too. I will have to look at the flow chart again and figure it out.
And yes that is the number I called yesterday. Voicemail was not set up and no answer the 2 times I called. I will try again today.
Thanks
/ Loader for YM155d #6
If I remember correctly that block is just a convenient place to attach fittings. It does not have anything mechanical inside. It just redirects the oil the same way that it is done on our diagram- just up by the seat instead of down by the pump.
/ Loader for YM155d
Thanks Aaron for confirming that. I will need to get a quote on a loader next and figure out the PB setup too. I will keep everyone posted on what I come up with for prices ect.
/ Loader for YM155d #8
I've got one of those blocks around somewhere, but I remember that even when the YM155s were new that block was not a really satisfactory way to run a loader. The flow was just too low. A better way is to simply add a small accessory pump to the front engine pulley. Yanmar made a kit for doing that and eventually sold them that way.
rScotty
/ Loader for YM155d
rScotty
Thanks rScotty, and now that you mention that I do remember seeing a 155 with a pump set up like you described, but didn't really think anything of if until now. I will have to see what a pump setup like that will set me back first before anything else.
/ Loader for YM155d
Coldwater did call me back late last Friday. Loader would be $2300, and approximately $500 to ship. So once I figure out the ideal hydraulic set up and price I will have an answer.
/ Loader for YM155d #11
Mine is a front PTO mounted pump. Totally separate oil than the trans hyd on the tractor. It is a yanmar loader and pump.
/ Loader for YM155d #12
So is my YM165D. It came that way from the dealer. Is your hydraulic pump driven axially off the front pulley with a coupling under the battery??
The YM165D is the same tractor as a YM155D.
rScotty
/ Loader for YM155d #13
Yes it is. The oil tank is the right side frame upright form the loader arms
/ Loader for YM155d
Can you post a picture of that pump and tank Chevy?
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
