YT359C bottom plow?
/ YT359C bottom plow? #1
bigweights
Member
john deere 4044m
Can a YT359c pull a bottom plow? What size? Do you think the IHMT can handle heavy tillage work without problems? I have 10 acres I plan to work up.
/ YT359C bottom plow? #2
I ran a two-bottom Ford Dearborn that I borrowed from a neighbor on my YT359C. I had no problems pulling this through the rocky clay that is common in our area. I did less than 10 acres, but I felt it went fast. The IHMT did not seem to bog down or struggle at all.
/ YT359C bottom plow? #3
Bigweights, How did this work out for you? I would expect you had no problems at all. This is where the IHMT should perform very well. The transmission should achieve hydro-lock(zero fluid pumping) somewhere in the middle of the gear range, the optimal point for minimizing energy loss and heat in the transmission.
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2022 Deere 317G (A64126)
2022 Deere 317G...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
John Deere 412R (A63688)
John Deere 412R...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
