adding more tires
/ adding more tires
STARCO Dual wheel HD - YouTube
watch this , Its the modern version of how duals were attached in the 80's the video after is an older tractor . this is how the wheels are added when you do not have an axle to mount a hub on . you would need a rim without the center to accomplish what you want
Thank you
I liked that video. I have been looking for something like that video for ideas.
That method looks to me like it would cause the tire rubber to hold them apart. It seems that could be an issue is a tire went flat.
If not for that one issue, I think this method would be the one I would use.
/ adding more tires
And this video shows a clamp on style
Why I like T-Rail Duals - YouTube
Thank you
for this video also.
I like that way better.
Though it seem the tires touching each other will still be an issue, the ease of taking off and putting on would minimize the problems of proper inflation.
I did not see what the clams are clamping to. Or I did not see the t-rail.
/ adding more tires #25
there is an EYE- bolt on the tractor rim the for the hook on the clamp.
I'm sure the tires are not touching if so its minor. the spacer in the outer rim is vital and will set the distance .
/ adding more tires
You posted the STARCO video and you said you had the T-rail.
Have you used the STARCO? Of the two Which do you like better?
/ adding more tires #28
i just was looking for a video to show how they work. The duals we ran back then when there were no 4wd tractors (except articulating kind) came with the tractors when they were purchased . I do not know what brand they were . We had 2 kinds of clamps the t rail clamp type and the other used a long bolt with a hook end that clamped on the tractor spin out rails . then later on the JD tractors they had eye bolts where the j hook clamped on. Can you build or possibly buy the outer rims and spacer you would need to mount your tires ?? probably. You will not get your current rims to work with out modification and some engineering.
/ adding more tires
THANK YOU to everyone for their thoughts and suggestions.
I now have an idea of my options.
I am going to probably wait out this year looking at swap meets. If I can find the parts I need, I will jump on them. If not, I will get the parts new.
The center hub will have to have the right bolt pattern and the right length. I need to measure for that to know what I am looking for if I come across those. I may decide to make them myself.
But I am leaning towards the T-rail.
/ adding more tires #30
I have an extra set of rear tires and wheels.
I was thinking about making my tractor a dually.
What would it take?
What would be the pros and cons.
My thoughts...
Pros more traction.
Cons have to take them off to load the tractor on a trailer.
What tractor???
On "most" smaller tractors, you should buy a spare axle to go with them, and read up on how to replace the one that's in your tractor now...
SR
/ adding more tires #31
What tractor???
SR
International Harvester 584
/ adding more tires #32
I added duals to my (7HP) Wheel Horse back in the day.
Like this?
SR
/ adding more tires
I wonder how they did that.
/ adding more tires #37
The easiest way would be photoshop.
I doubt the steering components could swing 7 tires forward or back to make this work. And if it did, you'd have to be very careful to not swing them back so far as to hit the rear tires. But the stress on the bearings and spindles would almost guarantee something would break every hour or 2.
/ adding more tires #38
I seriously doubt that’s real. First problem is moving that thing from one field to the next. Next problem is finding an implement that wide. Next problem is the stress on the machine. Next problem imagine having a flat on the inside one. Next problem is there isn’t enough weight to utilize that many tires. Next problem is hitting the tires against themselves or the implement while turning. Next problem is those tires are probably 2k each. I’d agree with the photo shopped option.
/ adding more tires
You are a very wise man!
/ adding more tires #40
It’s not even a very good photoshop job with duplicate features like chunks of mud on every tire. They could have at least added a longhorn hood ornament.
Case SV280B (A60462)
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2014 Econoline Trailers 29ft. 17 Ton T/A Dovetail Equipment Trailer (A61568)
2014 Econoline...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
2024 Scag Cheetah 61in. Zero Turn Commercial Mower (A61567)
2024 Scag Cheetah...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
