5010 Mahindra
/ 5010 Mahindra #1
rbgc64
Clinton ar
Mahindra 5010
My 5010 will start but dies as soon as key is released
Brand new key switch brand new shut off solinode
Fuses are good
The solinode works as should when the key is at crank but the steam is relased when key goes to run power
Any ideas?
Thanks
/ 5010 Mahindra #2
Put the key in the “on” position (not started) and start ringing things out with your meter. It sounds like you’ve already changed some parts so I’m assuming you have some basic mechanical knowledge.
Do you have anything in the on position? The normal gauges, initial start up sequence or no power to anything?
/ 5010 Mahindra
The all post at the switch are hot in the on position except the black. And blue ones
I assume the blue to be the starter wire since it goes hot when cracking
/ 5010 Mahindra
Oh and yes all panel lights are working
/ 5010 Mahindra #5
I guess the problem was resolved. It would sure be nice to know how it got fixed or fixed itself. I'm just saying.
/ 5010 Mahindra #6
Finger to side of nose.........some streets only go one way.
/ 5010 Mahindra #7
I have exact same problem and just purchased a new ignition switch.
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
SERVICE BODY TRUCK BED TOPPER (A64281)
SERVICE BODY TRUCK...
79" X 33" TAILGATE (A64280)
79" X 33" TAILGATE...
(INOP) 2013 JOHN DEERE TS GATOR (A64280)
(INOP) 2013 JOHN...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
96" X 20' TRI-AXLE TRAILER (A64280)
96" X 20' TRI-AXLE...
