What is correct way to use thread sealant?
   / What is correct way to use thread sealant? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I'm going to use thread sealant for the first time and am looking for pointers. Pic below. With tape, I wrapped three times and left the first two threads with no tape.
With thread sealant, how important is to leave the first two threads clean? How much sealant do I use and do I have to put it on all threads? How tight do I tighten? What else?
Most important, will it reliably seal my loader connections? I have to replace the connection where the loader hoses disconnect when you remove the loader. I'm replacing the junction box with a quick disconnect lever setup and don't want any leaks. I mean, I could still use tape. Advice welcome.
   / What is correct way to use thread sealant? #2
CAN OF WORMS OPENED!
The mechanic I learned from didn’t like the Teflon tape on hydraulic fittings. He used the paste. I’ve never heard that you should leave two threads without sealant. Most methods/products work fine if done correctly/per instructions. Your Teflon definitely falls in that category. I found a thread sealer that the folks who make loctite make. It isn’t loctite and looks like teflon paste but smooth. If I find it I’ll post an edit with a link. I’ve also seen good results with good old red loctite. It’s seals well but obviously can be a PITA when it’s time to disassemble the part.
Edit-
Permatex(R) Pipe Joint Compound - Permatex
I usually go about as tight as I can with about a 8” lever. Most wrenches are longer so I “choke up”. A lot of it is done by feel and with experience. The bigger the pipe/fitting the more leverage needed though. The above reference was for CUT sized stuff- 3/8”-3/4” ish stuff.
If you do end up using Teflon tape make sure to wrap in the same direction as would would to tighten the fitting.
   / What is correct way to use thread sealant? #3
I don’t like the Teflon tape. Aside from the possibility of getting pieces in the system you can’t back the fittings up any and that’s a frequent need with hydraulic parts. And my experience is the Teflon tape usually leaks.
   / What is correct way to use thread sealant? #4
I did a couple recently with dope and just made sure I didn't get any in the ports themselves. Didn't worry about keeping two threads clean.
But I've never done Hydraulic fittings before, so I may have messed up.
   / What is correct way to use thread sealant? #5
I use a Loctite product specifically for hydraulic fittings. Goop it on all threads, screw it down tight. It's off white and about the consistency of tooth paste.
I'm the OP on this. Is the sealer in the first post OK for hydraulic fittings? I can't recall but think it's the only sealant they sold. Anyone know?
   / What is correct way to use thread sealant? #7
I’m sure it will work fine. It should say something like water, fuel and oil. Teflon will work with oil.
   / What is correct way to use thread sealant? #8
Can't tell 'dogs. What does it say on the back of the tube? Pretty sure teflon type will work with most all oil products, Besides - if it's the only sealant they sold - what have you got to loose. Try it. If it works - great. If not - keep looking.
   / What is correct way to use thread sealant? #9
Read instructions on container..... This is my go to.. Use it on most everything....
Not a fan of PTFE tape always ends up a problem for me...
Dale
   / What is correct way to use thread sealant? #10
I sometimes just use Permatex #2 gasket sealer. Never had a problem with it.
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
2015 Hyundai Veloster Hatchback (A55758)
2015 Hyundai...
UNUSED TOY DIE-CAST REMOTE CONTROLLED EXCAVATOR (A54756)
UNUSED TOY...
2024 TEXAS PRIDE 40FT GOOSENECK FLATBED TRAILER (A54607)
2024 TEXAS PRIDE...
2025 CATERPILLAR HM316 - 72" HYD MULCHING HEAD (A52705)
2025 CATERPILLAR...
New Kivel Skidloader Double Bale Spear (A50775)
New Kivel...
