Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,911
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Most hydraulic fittings are tubing type with male/female connections or O-ring seal. The threads just hold the connection tight. Thread lubricant (it is never a sealant when the threads are made up properly) is used to lubricate the joint so the proper torque can be applied without stripping or galling the threads. If the threads are made up correctly, then regular grease could be used. Some products called thread sealant just fill in the gaps on improperly made threads and lubricate the threads so they glide smoothly to the point of tightening and therefore may or may not seal the joint and prevent leaks.
SAE pipe threads (and any other threads) can be tightened to the point of deforming the threads which can cause leaks with or without using thread sealant. In my career as a Quality Manager and Inspector, I have seen more threaded joints leaking from overtightening than any other cause.
