Front Tire cupping
   / Front Tire cupping #31
There is one detailed logical explanation. Not disputed or discussed, mostly ignored.
Perhaps because not many are convinced that it is in fact the cause of the O. P. problem.
   / Front Tire cupping #32
They will be tilting at windmills for a while. This is not a new or unique phenomenon. It may be a new discussion here but TBN does not attract a majority of mainstream Ag where this type of complaint is more common. There are a very few front axle and wheel adjustments and inspections to be made, if they are all good it is going to be roading on specific types of surfaces that created the wear. The OP cannot say one way or another because he recently purchased the tractor.
This is what is so great about forums, everyone gets to post an opinion, and everyone gets to take it or leave it. Its all good and not hurting anyone.
No hurry, have plenty of time to work on it
   / Front Tire cupping #35
Exactly! And until if/when the O.P. finds out what the actual cause of the unusual right front tire wear was and reports back, no one will know for certain. ;)
   / Front Tire cupping #36
I stood in front of my four wheel drive JD today thinking about this thread and looked very carefully at the tires. They are probably have about 50% tread on them but the tires show no cupping or uneven wearing and by eye site the amount of wear looked the same. I have looked back at the pictures as carefully as I can and my first view of them was the right front tire was cupping but don't think that is correct. Believe the front tires are being run with too high air pressure in them on hard surface road.
Verify the pressure in those tires.
28*F
Right 18 psi
Left 19.5 psi
Toe in between 3/8 to 7/16 using boards on outside of wheels
Tried to get an idea of the camber angle and seems the right side has a bit more then the left, and is compounded from the left tire being lower pressure. This could be correct due to crown of the road. Unable to get a angle on the hub but will remove the wheel after I get the motor running again and check on the hubs
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
John Deere 970 Cultimulcher (A52128)
John Deere 970...
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
