RTV plow won't angle
/ RTV plow won't angle #1
Tomtint
Elite Member
Boston
L3700SU
I have a Kubota RTV 1100 with the Kubota electric over hydrolic plow. It goes up and down, and angles left but will not angle back to the right. Nothing is bent and all the electric connections are good. It worked a month ago when I put it on..then today I went to move it and it would not angle.. any ideas ?
/ RTV plow won't angle #2
Make sure all the quick connects on the hoses are on good. It’s letting fluid go into a cylinder but not out. If those are connected good it is a check valve. Make sure the collars are all the way forward
There are no quick connects on this plow. It has a 7pin plug like a trailer would and that plug sends power to the plow. All the hoses are permanent and do not couple together
/ RTV plow won't angle #4
Ok. Is there a hydraulic block that the angle cylinder hoses go to? Sometimes there is a check valve in those
This is what it looks like
/ RTV plow won't angle #6
Maybe take a test light to the wire going into those solenoids. I’m guessing one is not getting the signal to open or it’s stuck
/ RTV plow won't angle #7
Sounds like one of the plug contacts isn’t making a good connection, could try cleaning them up,a dap of dielectric grease and check your ground.
I hit the plug with dielectric grease..first thing I did... it makes noise when I hit the angle button, so it's getting power. It's just not moving.
/ RTV plow won't angle #9
Have you loosened the hydraulic fitting on the cylinder that won’t move? See if you can determine if it’s getting flow or something is wrong with a cylinder. It’s a long shot but sometimes hoses collapse internally and make a check valve
I just tried that.. I had my wife push the up,down,left, right and I thought if I had the test light on which ever solenoid controlled that function..it would light up. But none of them do. ..but it still goes up and down..no lighting the test light up... there is a power in cable at the top of the motor and that lights up ghe test light. ..so it's getting power.
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
1008 (A61166)
1008 (A61166)
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2008 CHEVROLET COBALT(INOPERABLE) (A60736)
2008 CHEVROLET...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
