Replaceing trailer fenders??
/ Replaceing trailer fenders?? #1
John White
Gold Member
Newark, Oh
Bob Cat Ct335
Has any one replaced the fenders on their equipment trailer. I just bought a Load Trail 18" trailer and needs work. The fenders are cracked, bent, and rusted through. I would like to put the same style back on it. 9" wide 72" long steel with the tread plate pattern. Did you order them some where or have a fab shop make them? I am trying to find them in Ohio because the freight costs more than the fenders. Surely some one makes them in Ohio. I called Moritz trailer factory near me and they would not talk to me about buying fenders from them. In rebuilding a trailer, if you are not careful you can get more in it than you could ever sell it for if for some reason you didn't like it.
/ Replaceing trailer fenders?? #3
Check with Tractor Supply, they sell them and you can usually get stuff shipped to their stores for free.
/ Replaceing trailer fenders?? #4
The Tractor Supply stores near me generally have both single and double axle fenders in stock.
Aaron Z
I don't see any listed there like what I want. It is a equipment trailer. It is for 16" wheels, tandem. 9" wide 71" long, tread plate, they are flat on top with lip, then drop at about 22 1/2@ angle then another 22 1/2@ angle.
/ Replaceing trailer fenders?? #6
Something like these?:
no idea, in Ohio, maybe in Texashttps://trailerpartsunlimited.com/a...el-trailer-fender-72-l-x-9-w-x-17-h-14-gauge/
/ Replaceing trailer fenders?? #9
/ Replaceing trailer fenders?? #10
Yes that's what I am looking for, but the freight will kill me from Texas
Have you checked?
They are $71, vs $247 with free shipping that Aaron posted.
/edit - that's $71 plus shipping versus ebay rounded $247 shipped.
Maybe buy the steel and make your own.
Have you checked?
I sent the company a e-mail to get a freight quote. I would rather have the steel ones on a equipment trailer. I am hoping they have a place in Ohio where I could pick them up.
/ Replaceing trailer fenders?? #12
I understand the need for steel. My Hudson has heavy duty diamond plate. I think they are 1/4" or thicker. I stand on them frequently when loading the trailer.
/ Replaceing trailer fenders?? #13
Do your current fenders come off or are they welded on ? You might consider making them removeable - very handy when loading pallets etc. on an equip. style trailer as well as when opening doors on a trailered vehicle.
My Load Trail equip. trailer has them and are pretty handy. 1 bolt front & rear and they slip up & off the small brackets welded to the frame. Have to disconnect the wiring connector for the clearance light. Would be fairly easy to weld a couple small brackets to your frame and then weld a pair of matching gussets, 1 to the frame and the other to the fender and use a bolt & nut to secure. Those fenders in steel are fairly heavy though but plenty sturdy.
/ Replaceing trailer fenders?? #14
/ Replaceing trailer fenders?? #15
Check these guys too. They are easy to work with. But they are in Houston so, shipping.
trailerwheel.com
/ Replaceing trailer fenders?? #16
Freight will be cheaper if sent to a business, if you know someone who will let you send to them.
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
2022 EZ-GO ELITE...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2023 New Holland Boomer 45 Tractor (A65579)
2023 New Holland...
