Tractors rated hydraulic flows
/ Tractors rated hydraulic flows #1
Stomper
Gold Member
Saskatchewan, Canada
2017 Kubota L2501
My tractor's (Kubota L2501) hydraulic system puts out 5 gpm at 2200 psi. I have been researching and found a hydraulic motor for a project I am building. The performance data for the motor says that 5 pgm flow will give me the 60 rpm that I am wanting. My question is, at what engine rpm are tractor hydraulics rated. In other words, to get the 5gpm flow what rpm would the engine be rinning. I want the motor to run at 60 rpm when the tractor engine is at or just above idle not at or near max rpm. How do I figure this into the selection of the motor.
The motor that I found is 15.4 cu.in. motor. How do I know if this motor is sized right or if I need a smaller or bigger flow motor to get the rpm I want at or near idle.
/ Tractors rated hydraulic flows #2
the stated flow will be at either rated rpm or max rpm, in your case the only speed they give is 2200rpm. At idle your engine is approx 1100rpm. The system flow will be less than 50% due to lower pump efficiency at the lower speed, but the exact amount will depend on several things including pump wear, system pressure and oil temp (ie actual viscosity). I'd figure on approx 45% of rated flow. So 5.5gpm x 45% = 2.48gpm
On the motor side you also need to factor in some inefficiency if you are trying to get 60rpm on the nose. You didn't say what kind of a motor so I'll use 93% for a gear motor. 2.48gpm x 93% = 2.30gpm flow available.
motor size = (2.3 gal/min x 231 cubic in/gal) / 60rpm = 8.86 cu in/rev. Depending how tight you need to regulate the speed you may need a flow control. and obviously if you rev the engine it will roughly double the speed. Also, at idle this motor would put out approx 2.9hp.
ISZ
/ Tractors rated hydraulic flows #3
Rated flow in a brochure or manual is at the pump, you won't get that out of the remotes, and "sometimes" some of that flow is used for the power steering too...
Some tractors do have two pumps, with one for the power steering and the other for the rest of the tractor.
So you have to be carful about what you will REALLY get out of a tractors hydraulic system.
BTW, the GPM rating, is at max RPM...
SR
/ Tractors rated hydraulic flows #4
How about a bigger, PTO driven pump that can make the flow at the engine RPM you need?
Everyone seems to be saying the same thing- it either won’t work or is marginal at best.
/ Tractors rated hydraulic flows #5
pto pumps are great, but then you have to have the hydraulic tank ect. to go with it...
SR
/ Tractors rated hydraulic flows #6
SR
Yep, depending on what OP is doing he could tie into the existing case. But the PTO option is definitely more involved.
If it’s for a auger or something it would be easier to get a motor. But if he must use that size the PTO could work.
/ Tractors rated hydraulic flows #7
The only way to know what your tractor is putting out is to measure it with a flow meter.
/ Tractors rated hydraulic flows #9
SR
According to the info I found there is a separate power steering pump, so no flow sharing. Brian
/ Tractors rated hydraulic flows #10
Most manufacturers use two pumps now. I haven't seen one that doesn't though it's possible someone still uses a single pump. I think that's simpler and possibly safer than diverting flow to the steering.
Some manufacturers add the power steering flow to the main flow and use that number in their litterature even though there's no way to combine the two other than on paper.
/ Tractors rated hydraulic flows #11
Some mfg's say "combined flow" and if you are new to tractors, that can be confusing...
Regardless, you will NOT get pump rated flow to the remotes, there will always be some loss'.
SR
/ Tractors rated hydraulic flows #12
It would be safe to assume the "rated" flow rates are at PTO RPM.
/ Tractors rated hydraulic flows #13
You’re spending a lot of time think8ng about what flow your tractor will MAKE
Have you asked the question about how much torque you NEED the motor to make ? Select the motor based on this, and the available pressures, first
Just looking at RPM is a good way to size a motor wrong and be dissatisfied with the performance.
/ Tractors rated hydraulic flows #14
I have a 2005 tc25 S with a bush hog 2246qt loader on it that can’t hardly pick up anything. Previous owner had put a new pump on the tractor and a new cylinder on the loader. I didn’t test it with any weight when I bought it. Is the 2246 QT loader too big or requires a larger gpm flow.? What should the gpm on the tractor should be? Is there a high flow pump available? Any help would be greatly appreciated.
Anyone in Savannah Georgia area willing to take a look at it?
/ Tractors rated hydraulic flows #15
Larger GPM will NOT increase the power to lift something, you need higher pressure to get more power.
Higher GPM will make it move faster though.
SR
/ Tractors rated hydraulic flows #16
I bought a pressure gauge, hydraulic tee and connectors so I could check the aux pressure on my V417 Versahandler.
For your tractor a 3000 pound gauge would work best on the input to the loader from the pump. Connect it so the flow is through the tee to the loader.
View from the seat:
/ Tractors rated hydraulic flows #17
The motor is for a capstan winch that I have been researching. Someone on another forum gave me this link which will definitely help for motor selection
Assuming that the pumps rated flow is at PTO speed which is 2000RPM, this would suggest that you have 750 rpm*5.15 gpm/2000rpm= 1.93 gpm. This is hardly anything. I think you will need to plan on running it at pto speed.
That sounds like an interesting idea. What are you using the capstan for?
I have used catheads (horizontal capstans) quite a bit when doing water well servicing. They provide amazing control. It was my experience that the hydraulic units slowed down considerably with a load. The higher the load the more they slowed. This was frustrating when trying to ease into something that the load would get heavier on such as lifting pipe off the ground. The mechanical catheads would stay the same speed. Smeal / Hunke for the 5T pump hoists used 101-1005 (11.3 cu in) motors with a 14 tooth sprocket on the motor and 36 on the cathead for the indirect drive and a 104-1143 (24 cu in) on the direct drive catheads. I am not sure what the flow rate is on the hoists but they have a flow divider to control speed.
/ Tractors rated hydraulic flows #18
For a simple capstan, I'd be thinking about a mechanical pto driven setup especially with the exceptional control they offer and no need for reversing.
Any right angle gearbox from an old mower, post hole digger or even a small car axle could be used. Now you'd be working it down near an idle.
/ Tractors rated hydraulic flows #19
I used a pump hoist that had a ford AA axle (5.17:1) that had been modified with catheads on both ends. At an idle with a 21 hp 540 PTO running it it was perfect for work. With heavy loads it did not slow down much. If it did a mid speed idle kept it at a manageable speed.
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2018 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2018 Chevrolet...
330 GALLON POLY TOTE W/ CAGE (A62131)
330 GALLON POLY...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2025 Swict 84in. Skid Steer Bucket Attachment (A61567)
2025 Swict 84in...
