Snowplow for Kubota RTV900
   / Snowplow for Kubota RTV900 #11
I thought I'd send photos of my completed plow setup.
I bought the plow itself, which was designed to be lifted by a winch.
I set it up for hydraulic lift.
The lift piston, which is powered by the aux. hydraulics, attaches to the front 1 1/2 inch receiver hitch.
The lift works great.
Total cost for the lift system was about $190 plus $679 for the plow itself.
I really like that set up. I'm not so handy so I went with a winch lift system:
   / Snowplow for Kubota RTV900 #13
My RTV1100 has an Kubota OEM Curtis hydro power angle. The lift is a self contained electric lift actuator which stays with the plow frame. I don't have a winch.
   / Snowplow for Kubota RTV900 #14
I have a brand new (well, 15 hours now) Kubota RTV-X1100C with the Kubota plow and it definitely has self-contained hydraulics. It mounts in the UTV's 2" front receiver and you have only one IMG_2594.JPGelectrical plug connecting it to the machine, no hydraulic connections like I had on my old JD Gator with the "PowerTach" plow. The Kubota plow gives you up, down, left, and right and actually works better than the fully hydraulic plow I had on the Gator. I was worried about a lack of downforce, but just the weight of the plow provides plenty of ability to scrape off packed snow and ice.
I have a brand new (well, 15 hours now) Kubota RTV-X1100C with the Kubota plow and it definitely has self-contained hydraulics. It mounts in the UTV's 2" front receiver and you have only one View attachment 586922electrical plug connecting it to the machine, no hydraulic connections like I had on my old JD Gator with the "PowerTach" plow. The Kubota plow gives you up, down, left, and right and actually works better than the fully hydraulic plow I had on the Gator. I was worried about a lack of downforce, but just the weight of the plow provides plenty of ability to scrape off packed snow and ice.
I too prefer the plow to float using the plow weight to follow the ground contours. If down pressure is needed I can slip a piece of pipe over the lift chain.
You guys with cabs have it pretty good. I've been looking online for at least a windshield and a roof. My tractor is also "open" so no help there.:(
Fortunately I don't have much plowing to do and it should go faster now that I have a plow, instead of using the loader on my narrow curvy driveway.
   / Snowplow for Kubota RTV900 #16
You got that right, we'd not even consider a machine without a cab. Of course, most of the work we do with these machine is in the winter.. Why did I buy a 6x6 Boss???? :laughing:
When you mentioned Boss, I thought you bought that Boss plow, not a Boss machine.:eek:
   / Snowplow for Kubota RTV900 #18
I had an Eagle plow mounted on my Gator for a couple years...winch lift and manual angling. It worked great for the smaller snows we get in Vermont. I'm sorry I ever sold it...
One recommendation for those who use a winch to lift the plow...get a boat trailer strap to replace the cable on your winch. The constant lifting and lowering of a plow is tough on a few inches of the cable. The boat straps handle the lifting and lowering much better.
Something like this:
https://www.amazon.com/Shoreline-Marine-Winch-Strap-2-Inch/dp/B07KX75CVS
   / Snowplow for Kubota RTV900 #19
Very nice setup!!! 1100C is on my want list!!!!
Welcome to TBN!!!
   / Snowplow for Kubota RTV900 #20
Welcome to TBN!!!
Thanks! I'd been looking at the 1100C for a long time and now that I have one I wish I hadn't waited so long.It's a great machine!
Terex TB44 44ft Telescopic Boom Lift (A55851)
Terex TB44 44ft...
2013 POLAR TANK CRUDE TRAILER (A55745)
2013 POLAR TANK...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
CAT 420D IT (A47477)
