Replacing Bolts On ROPS With a Hitch Pin????
   / Replacing Bolts On ROPS With a Hitch Pin???? #62
Ok, make me two and I'll give you a twelve pack. Please let me know when you are done...:)
And we were talking about these:
Grade 8 Hitch Pins Archives - PaulB Parts - Ag, Industrial, and Mechanical Supply
Yes, those are even easier if that crosshole position is long enough. It may take a bigger lathe to accommodate the wire handle within the headstock. Depends on the lathe chuck.
To be clear, you would have the full 5/8" for strength and a smaller diameter just thru the nut.
   / Replacing Bolts On ROPS With a Hitch Pin???? #63
I still think your most simple 'fix' would be to chase the threads on both the nuts and pins, maybe several times, maybe with cutting oil to make the pins easier to thread in/out. No alterations to cause warranty/service/safety issues.
CUMMINS 230 KW GENERATOR (A57192)
CUMMINS 230 KW...
UNUSED 1RANCH 1RIF 111.02" X 64.96" WROUGHT IRON (A57193)
UNUSED 1RANCH 1RIF...
Bobcat T590 (A53317)
Honda UTV (A56859)
Honda UTV (A56859)
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
2018 Ford Explorer SUV (A56859)
2018 Ford Explorer...
