Replacing Bolts On ROPS With a Hitch Pin????
   / Replacing Bolts On ROPS With a Hitch Pin???? #62
Ok, make me two and I'll give you a twelve pack. Please let me know when you are done...:)
And we were talking about these:
Grade 8 Hitch Pins Archives - PaulB Parts - Ag, Industrial, and Mechanical Supply
Yes, those are even easier if that crosshole position is long enough. It may take a bigger lathe to accommodate the wire handle within the headstock. Depends on the lathe chuck.
To be clear, you would have the full 5/8" for strength and a smaller diameter just thru the nut.
   / Replacing Bolts On ROPS With a Hitch Pin???? #63
I still think your most simple 'fix' would be to chase the threads on both the nuts and pins, maybe several times, maybe with cutting oil to make the pins easier to thread in/out. No alterations to cause warranty/service/safety issues.
UNUSED SDLANCH SDLC2030FT20'X30' ALL STEEL CARPORT (A57193)
UNUSED SDLANCH...
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
2006 Ford F-750 Stellar 6620 6,000 LB 3 Ton Crane Mechanics Truck (A55852)
2006 Ford F-750...
2008 Chevrolet 2500HD Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
2015 John Deere 5085E (A53317)
2015 John Deere...
UNUSED GRASSROOTS IMPLEMENT 4' BOX BLADE (A57192)
UNUSED GRASSROOTS...
