Need some help picking an solenoid valve
/ Need some help picking an solenoid valve #1
Cord
Richfield, Wi
Resident Architect
I'm looking to add a second accessory port to my skidsteer. I currently have one circuit that is controlled by a manual valve and I want to split it's flow. To do this, I'd like to add a solenoid selector valve that let me choose between the two circuits. For example, port A is active when the valve is off. Port B is active when the valve is on. I do not need to split the flow between the two ports at the same time. I do not need a relief and I believe I want a closed center valve. There are lots of posts on this forum for people adding a third function to their loader; the problem is flow. Your loader circuits are pretty low flow so a 10gpm valve is sufficient. Well, my pump is rated for 31gpm so I need a valve that is listed for not less than 24gpm and more certainly wouldn't hurt. I've been unlucky finding the correct valve on Fremont or Surplus Center sites. Any other suggestions?
/ Need some help picking an solenoid valve #4
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
