Re-plumbing 3rd function valve
/ Re-plumbing 3rd function valve #1
tvman
Lebanon,In.
Kubota 4330HST
Need some advice on re-plumbing my 3rd function valve. My current set up is the typical electric solenoid and a DO-5? plate which is fed from my power beyond.
My tractor also has a BH circuit, it seems that the hydraulic hose is 1/2" in and out of the DO-5 plate.
I would like to replace this short section of 1/2" hose with 1/4" hose. If I do this will it create a problem wit lack of flow to the BH?
/ Re-plumbing 3rd function valve #2
The 1/4 hose will have more pressure loss per foot than 1/2 inch will.
Depending on the pump flow this loss could cause your system to run hot.
/ Re-plumbing 3rd function valve #3
Restricting volume (pressure would be the same) will generate heat and slow functions. If you said it was just a 3rd function for a snow blade or grapple I’d be less worried than a BH. The BH likes multiple functions at once and tends to get ran for long periods.
The make ultra flexible hose. I’d consider rerouting the 1/2” line with new hose- if the issue is that it’s in the way.
Thanks for the response guys. I wish I knew how to post pictures, it would likely help explain the issues I'm having.
I did go back and looked at the video of Cal Attachments installation. At this point, I am thinking of mounting the valve in a different location. In it's current location I can't access the QC's to disconnect the hoses going to the front of the loader. Any ideas?
/ Re-plumbing 3rd function valve #5
tvman
To post your pics, click the "Go Advanced" button, where "manage attachments" for valid file extensions shows up. Click that and you will see how to "Add Files" , browse to locate the ones you want, then "upload" them.
Should be all it takes... good luck
tvman
Thanks, I might try this when I get it finished. I have already removed the valve and re-mounted it on the loader arm.
I am currently waiting on a couple of fittings to finish the plumbing and then I want to add a cover to protect the valve.
Scag 36 Advantage (A64912)
Scag 36 Advantage...
New Holland TS110 (A64911)
New Holland TS110...
AUTOMATIC TRANSMISSION / TRANSFER CASE (A68842)
AUTOMATIC...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
2010 . TRIAXLE LOWBOY (A67714)
2010 . TRIAXLE...
