House Build
/ House Build #1
bannerd
Brunswick
Massey Ferguson 165
Is there anything out there that will allow a concrete truck to back up to a bin with an auger. Pump trucks around here are insane and I can't justify paying 20K putting a 30x50 house foundation in the 40K range.
I was thinking a little over half yard of concrete could be dumped into a bin with an 8"/6" hose hook up that a backhoe could lift and gravity feed or force with a auger. I remember doing my fathers house and he used 5/8 rebar with a lot of cold joints and it still stand 40 years later. I would like to avoid this and at least get a decent pour for the footers/floor and ICF walls.
Let me know !
/ House Build #2
I would think that the truck could reach 15' easily assuming you have access to both sides of the 30x50 slab. If not, maybe you could leave about a 10' section of foundation undug so the truck could back into the area and pour as it pulls out. Then when you're close, dig out the last piece of foundation and pour that with the last truck.
I don't know about gravity feed. I don't think it would work very well unless the concrete was really watered down. There are auger buckets with hoses that will pump it horizontally quite a long way. I've seen them used for pouring patios in housing developments where there is only a 5' wide access to the back yard. Don't know where you'd find one though.
/ House Build #3
I guess I'm not quite understanding the restrictions? A chute will easily reach 15' when pouring down from above the basement. They do make concrete pumps that will push concrete various distances. I'd starting calling some local mix plants and contractors to see what your options are.
/ House Build #4
There's a half dozen ways this could be done. For ICF, a pumper truck is without question the most productive. Don't forget, you're not just paying for the truck, but also for the masons who are standing around waiting for concrete.
There are concrete buckets which can be rented that would be mounted to the forks or hung by a chain from a telescopic forklift. It's slow (see above), but would get the job done.
BTW- cold joints are a failure insitu and are structurally unacceptable.
/ House Build #5
Here's a picture of what I was referring to in my post above. You should try contacting a rental yard or some of the concrete or masonry contractors to see what they can do.
/ House Build #6
Once the concrete starts pouring, you really want it to be done as quickly as possible. Pumpers are expensive, but a lot cheaper then a poorly done concrete pour.
If you cannot get the cement truck close enough to the forms, and there is no way that you will pay for a pump, there are attachments to pick up a yard of concrete from an excavator or a crane that is picked up and held over the location you want it poured. A lot of commercial concrete companies around here in East Texas have them and they use an excavator to do this. It really depends on access and how much you can save.
A picture of the site and the forms would be very helpful.
/ House Build #7
Let me know !
Here's how the stem walls were poured for the foundation of my manufactured home in 2005.
The contractor used an trailer mounted concrete pump. Worked like a charm. Took about 2 hours to make the pour.
Good luck
/ House Build
The house sits on a knoll, there is access to the top back side of the house. The front of the house that over looks a pond is the main problem. I had a site inspector come out from the ready mix plant and they can get the footers poured at the back side of the house footers. The main problem of concern is the front side which also has a frost wall. We thought about getting the concrete truck up the hill but with all the sand under the gravel road it's not possible as the truck would sink. Something like 3T is showing is what we need, the auger would force the concrete down the tube. The trucks could back in from the top side of the hill and pour from that remote site.
/ House Build #9
A concrete pump uses a piston to pump the concrete not an auger.
They are common around here.
Should be able to rent one.
/ House Build #10
Nothing will be as fast and efficient as a pumper, and making your own auger system seems ridiculously time consuming for this one project. But what about a tractor bucket? Do you have a fairly large tractor where you could make trip after trip from the truck to the forms? Might work for footings, but not for slabs. The finishers wouldn't like it, the reach is very limited and it will be slower, but it meets your goal of no pump.
/ House Build
580C backhoe with a over sized bucket, extendahoe on the rear is parked on site. I think I might get some crusher run and just build a road up to the footers. Then pumper for the icf when that time comes from the back side. The floor she's not sure on cause of a root cellar.
Can always remove the road later as well.
/ House Build #12
I hired a pumper three times over the last six months. Two different companies. $475 once. $575 the next two. Cheapest worker on the site. More than pays for itself in gained efficiency.
Hate it for you that they are so much higher there. You'll spend $1000 real quick trying to manually move your comcrete.
/ House Build #13
a large bucket on a front end loader,
or even a small dump truck,
and in the good old days, they had these things called wheelbarrows, (pushed one of them around alot when I was a young, pouring floors and footers), have a smooth path and get a few strong kids, (16 to 30), and let them move it for you, (even a few lawn mowers and those garden carts that dump, "Steel Trailer Dump Cart"),
I use my dump cart to haul old concrete, wet concrete, and a lot of other things, that least an old guy can more a lot of heavy things reasonably fast,
and they make motorized wheelbarrows, look up "muck truck", i use mine all the time, (now I made mine out of a old lawn tractor and a power washer engine, (but looks like a muck truck, and will climb stairs, with a good load if needed,
grand son runs it all over the farm, (I made it to pour concrete in a old shed 50 feet deep by 16 foot, wide, and it will go through a 36 inch door,
/ House Build
Yeah, those carts are pretty slick. Have to figure it out this summer, engineer is willing to look at the site to see what options we have. He did call around and the average cost of a pumper is 900 an hour plus fuel and additional yard tax ($15 per yard poured). A lot cheaper and some of the people I already called.. We will need the pumper two times, footers and mid slab, then ICF walls. The time involved will be the trucks as the house is about an hour and half from a ready mix plant.
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2015 Caterpillar 304E (A64126)
2015 Caterpillar...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
Skid Steer Post Auger (A65640)
Skid Steer Post...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
