Couple quick projects
/ Couple quick projects #1
plastikosmd
2 quick projects
First the crappy snow shovel. Broke the handle and couldn稚 bear to throw it out. 18$ shove and bought a 9$ handle. Neede to shim it and this should hold better(at least until the shovel part breaks)
Second was a slightly bent arm on this jack. I broke a toe when using it to remove a carriage from a forklift. Put it in the hossfeld bender to tweak. Not perfect but better. Stopped when I moved the 1500lb bench.
/ Couple quick projects #2
We all need to decide whether to fix something or just toss it. I can admire someone who can repair their tools to better serve them when needed.
Amen
Couldn’t bear to throw it out
18.99 replacement cost with weak handle, likely to break again vs 20 min and a 9.99 handle
Will see
If it holds!
Just me, available for hire
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2017 Ford F-150 XL (A64127)
2017 Ford F-150 XL...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
