Defroster in Cab
/ Defroster in Cab #21
Alright! Good answers all!! I will take a look at the outside air selector and see about getting it fixed. An external fan is a good idea too, but maybe too evasive and nightmareish to install. I'll try with a side window open and see if that helps.
I figured it was due to lack of air flow over the windows. To be honest, I totally forgot about the selector being broken until someone mentioned it. I have no idea which way it is stuck. Could be open to outside already.
Thank you all for the responses. I will do more digging and hopefully be able to see out this winter!
I always wondered why the left and right defrost vents are installed with the louvers adjusting to the middle of the cab verses being able to point them at the door glass.
Those have to be able to be removed and turned 180 so the louvers point the other way.
/ Defroster in Cab #22
I was coming here to say exactly that. I popped out 2 of the vents in the front, spun them 180 and snapped them back in. Also doing all the interior of the glass with anti fog helps a little.
Jay
/ Defroster in Cab #23
Jay
Was there any trick to popping them out?
/ Defroster in Cab #24
Jay
Thanks for this info. Going to do the same.
/ Defroster in Cab
That sounds like a fantastic idea! Why didnt I think of that?!
Any method or trick to doing this? I would hate to break flimsy plastic and no control where the air goes.
/ Defroster in Cab #26
You can always pay the stealer for new ones and put them in the direction you want.
/ Defroster in Cab #28
Very simple fix. There are two tabs on each side. Use a small flathead screw driver and push them inward. Then pull the vents straight out. Flip them around and reinstall.
/ Defroster in Cab
Thank you for the replies! When I get a minute, I will certainly do this. I do believe this will fix my issues. When the tractor I mean. :)
1980 Yamaha Sun Classic Golf Cart (A66408)
1980 Yamaha Sun...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
John Deere Lift Arms (A65640)
John Deere Lift...
Landhonor Quick Attach Rolling Packer (A66408)
Landhonor Quick...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
