Starter wiring trouble.
/ Starter wiring trouble.
The engine runs and can be turned freely by hand. the jump box is a 50amp starter. I'll test the amperage when I get a chance
/ Starter wiring trouble. #22
are you soley using a jump box? with out batterys in line?
50 amps is not nearly enough to turn most motors, motors in cars start at 200A on crank all the way up to 400 etc....
charge the main batterys up, use a set of jumpers off that and hook your jump box to your batterys.
what kind of voltage are you seeing at the starter lugs when you tell the starter to engage? anything under 10 is usually a problem
/ Starter wiring trouble. #24
hand spring clamps just can't pass enough amperage
My jumper box has jumped my IH584 more times than I can count.
that is connected to frame and starter.
/ Starter wiring trouble. #25
Was that with a low battery connected or no battery? The teeth on most clamps don't provide enough surface area to pass a lot current, going directly to the starter terminals helps and I don't know what takes to turn a IH584, but you won't start my 7.3 liter diesel that way there is a reason it has twin batteries and cables the size of your thumb. Also the starter my sound fine on the bench but still have a bad solenoid that won't pass enough current, open and inspect contacts, sandpaper and bend into good alignment
/ Starter wiring trouble. #26
My 584 is 60hp 3.4L
OP 414 is 2.3L 45.5hp
Why would you equate you 7.3 L to his 2.3L
/ Starter wiring trouble. #28
I have not see many jump packs that could start an engine without a battery in the system.
The internal battery may only be 50 cold cranking amps.
Your replacement IH starter should have a solenoid mounted to the starter,
the solenoid should have a large terminal with no wires attached, the battery cable
from your old starter should go there.
There will be one or two smaller terminals on that solenoid.
A jumper applied from the solenoid battery terminal to the smaller terminal should engage the starter,
or use a remote starter switch such as,
Heavy-Duty, Remote Starter Switch | OTC Tools
/ Starter wiring trouble. #30
I have an international b414 diesel...
As I recall,2 batteries are parallel 6volt positive ground,has that been altered?
You are correct it is positive ground. Nothing has been altered yet.
I will say this is my first positive ground tractor and I would like to convert it to negative.
It should be a neg ground.
unless it was made for the UK, they like positive ground for some reason!..
The owner's manual say's it is positive ground.
The shop manual say's it is positive ground.
OP say's it's positive ground.
Jax say's it's positive ground.
Why are you saying it's negative ground after all that?:confused3:
/ Starter wiring trouble. #31
WHO are you replying to?. if Me, I never said it was negative ground, it may be positive ground made for the UK, as that is what they like, the U.S. uses negative ground.. and to use a tractor with positive ground in the U.S. is looking for electrical trouble. all accessories made for the U.S. use negative ground, and if someone is not familiar with the tractor, they could wind up jump starting the batteries reverse polarity..
/ Starter wiring trouble. #32
Mine was an auction import from Europe.
But the US service manual said they are all neg ground.
Great Dane Van Trailer (A63689)
Great Dane Van...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
John Deere Worksite Pro RS72 (A64119)
John Deere...
2025 44in. Hydraulic Stump Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
Fimco 45 Gal Sprayer (A64119)
Fimco 45 Gal...
