century 2535
/ century 2535 #1
dannyrolen
2002 century
i need a radiator for my century 2535, if any one knows of any one with a radiator i wood like to talk to you. thank you very much. this is d rolen
/ century 2535 #2
Have you considered having it recored\repaired. A local radiator shop may be your best friend.
/ century 2535 #3
I second that. Just take it to a good local radiator shop and have them either repair yours, or build you a new one outright, using yours as a template. Even if they have to custom build you one from scratch, it will be cheaper than buying a factory replacement part (if you can find one).
/ century 2535
thanx for the info. it's greatly appreciated,but i didn't quiet make my post as to what i really needed. so sorry. what i need is the top plastic cap that goes across the top of the radiator. any ideas? any info would be helpful. again, thank you sincerely
/ century 2535
tank you but what i really need is just the plastic cap that goes across the top of the radiator. sorry for confusion.again thanx for your reply.
/ century 2535 #6
I am still confused. Maybe a picture? What is the function of the plastic cap? To contain airflow through the radiator? Can you fabricate something? I encased all around my radiator with foam rubber and/or fine wire mesh screen to keep debris from getting into the front of the radiator. Helped tremendously.
/ century 2535 #7
Agree with Cougsfan.
WTH is a plastic cap?
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
(INOP) 2009 FORD CROWN VICTORIA (A59823)
(INOP) 2009 FORD...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
EZ-GO Electric Golf Cart (A60463)
EZ-GO Electric...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A60736)
2008 TEXAS BRAGG...
