storing tractor for years
/ storing tractor for years #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
I am moving and not sure when I will use tractor again, have to find land, build, could literally be years, it will be stored inside.....owners manual says to drain and change all fluids, I just did the oil and coolant this yr, tractor has 400 hrs, owners manual says to change hyd at 500, should I do before storage? It says to drain fuel and add 2 gal of "fuel injection pump calibrating fluid" Not even sure what this is. Also to fully raise lift linkage and support lift arms, it has 3 pt and FEL, not sure why to raise? Tractor is a diesel w/ a fuel injection pump. Stabil is only good for 2 yrs I think. I was thinking of just draining fuel, running till dies and leaving empty, would this be bad? Any help is appreciated.
/ storing tractor for years #2
There is nothing worse for a machine than letting it sit idle, regardless of how it's prepped for storage.
Sell it now, invest the money and buy a new one when you finally get back around to needing a tractor.
/ storing tractor for years #3
A few won’t hurt a diesel tractor. I wouldn’t run the tractor out of fuel. There’s no telling what will dry out that wasn’t supposed to. Diesel will last years. If it’s stored inside I’d park it and forget about it. If it’s going to be stored outside I second the idea of selling it.
/ storing tractor for years #4
By any chance, do you happen to a friend that you trust that could keep it inside at his place, and start it up and move it around once in a while ?
/ storing tractor for years #5
Don't change the hydraulic oil now. It doesn't need it. Don't drain the fuel. It doesn't need it. Put in some fuel stabilizer. Try and run it for half an hour or so every 3-4 months if you can. You might also want to put it up on short jackstands. Just enough to keep pressure off the tires so they don't get "set" with a flat side for months at at time. Do everything the manual says for long-term storage would be the best advice, though.
/ storing tractor for years #6
I wouldn't hurry to sell it. You will pay a lot more to replace it with a comparable tractor. Your 451 has low hours for the age and you know how it's been treated; yet it's old enough so that it won't depreciate much more. If you decide to sell further down the road you will still get about the same amount of money.
You have a dry place to store it, so it isn't going to deteriorate the way that it would if stored outside. I would do as the manufacturer says, then check on it periodically.
/ storing tractor for years #7
I don’t think you’ll make enough heat in 30 minuets to evaporate the water out of the oil and you won’t burn enough fuel to replenish that so I don’t think you’re doing it any favors with such short use. Than again that’s about all my tractor does. It at least gets several hours use at a time a couple times a year.
/ storing tractor for years #8
If you drop it off at my place I will keep it in the shed ! Fire it up every couple of days to do a little work around the place! I will keep the fuel tank topped up! And I won't even charge you anything!
/ storing tractor for years #9
I said "run it", not idle it. Run it for 30 minutes. It should get up to temp in 10 minutes at PTO speed no problem. If it doesn't, there's other issues. It should also use probably half a gallon of fuel, give or take, and it will be plenty of time to agitate the fuel in the tank with the return line, so all that good stabilized fuel will be recirculated through the entire system several times over.
/ storing tractor for years #10
That's why I like TBN! So many people willing to lend a hand. :D
/ storing tractor for years #11
Sell it now, invest the money and buy a new one when you need a tractor again.
I agree.
Unless you are mechanically adept, you may face a substantial cost to return it to running order.
In the meantime it could be stolen, your storage area could burn or a nefarious family relation may sell it. (Tractors have no titles.)
You could experience a major health incident.
Implements will be rusting outdoors.
Your need for a tractor, or size of tractor, may change during your absence.
/ storing tractor for years #12
I would agree - a unit just sitting around "years" is a recipe for problems to develop - machines typically need the fluids maintained yearly - rubber /plastic decays even if its not used and there are issues that long layoffs may cause that are worse than heavy use on the machine.
That said - a machine stored indoors and ran regularly can last an extended period of time and should not fail sooner than one used lightly regularly. They are machines - not animals, they will not atrophy because no one took them on a long run every week/month. Will things wear and require replacement regardless of use - yes - but they will not fail faster because you used them less than a normal user if maintained properly.
Time frame is a concern here - "could be years" - is a fairly loaded statement - I "could" win the lotto tomorrow too and stop posting here forever...but being a betting man I'd venture to say I'll still be here. What are the chances it will be years for you - and what are the chances this unit will be under/over sized for your future needs.
Lots of people store equipment over the winter with no to minor issues - so a 4 month time frame is no big deal. A year - some minor prep and planning goes a long way...2 or 3 years - I'd start with a 1 year plan and then adjust as needed. If theres a greater than not chance its going to be 5 years of inactivity - its time to sell. In 5 years you might get a nicer unit than what you sold today for the same price.
Indoor storage you've already addressed and is a must in most places. As mentioned having someone run equipment (actually moving it and activating PTO/hydraulics) is a very good idea...a simple idle in place does not do alot. Keep the battery on a low volt charger to maintain charge - make sure you keep things open and can see areas where rodents may try to build a nest and keep them clean. Its tempting to just toss a tarp over things - but thats the perfect hiding spot for mice/birds.
Keep a maintainer in the fuel and keep the fuel level lower so that you can burn it off and replace regularly.
I'd keep seat covered with plastic as well - again rodents and foam are a concern.
Edit to add - could it be stolen - yep, nothing that prevents a regularly used item from suffering the same fate though either. Obviously a property with no signs of regular visits is more inviting to thieves - but this is common sense. Cameras are great at showing who did what when - lighting and regular visitors/neighbors are great at keeping them from coming around. Same as a fire to the storage building - there are perils that apply equally to operated/non operated equipment and do not increase with non use.
Family selling equipment out from underneath you - sounds like a very specific issue and wouldn't term it "common"
Implements rusting away outside - easy enough to correct, store indoors and if they wont be used at all for many years and cant be stored inside - potentially just sell the implement(s) alone.
/ storing tractor for years #13
LOW AMP charger...not... "low volt"
/ storing tractor for years #14
If I...disconnect battery disengage the clutch,maybe spray wires electric connections help keep rodents from chewing etc.
/ storing tractor for years #15
If you plan on keeping it, I’d take the battery out, lightly oil the cylinder rods, and ensure all grease jerks have a dose to add to the preparation list. Putting it up on blocks to take pressure off the tires would definitely be recommended!
/ storing tractor for years #16
Out here where I live - in the middle of BF nowhere - there would be no questions. I would have to sell. There would be untold & expensive damage from rodents - rubber components could be seriously deteriorated & there is a potential that the tractor could be stolen. Plus the consideration - that even in storage you will want to continue some form of insurance on the tractor.
Also consider - many years from now - you may need to sell this tractor - for whatever reason. Do you want to risk the potential necessity of repairs - just so the tractor could be sold. Besides - with the tractor sold - funds safely tucked away - you have none of these worries.
I would sell the tractor - set the funds aside in some form of interesting bearing account - THEN, make your decision on purchase of another tractor, in the future.
JMHO - but for me, this would be the very best I could do.
/ storing tractor for years #17
If you do decide to sell, please list it on the TBN marketplace. Depending on the price and cost for shipping I might be interested in upgrading.
/ storing tractor for years #19
If it has a clutch, will likely have a lock that will keep it fully depressed, if not make some that will keep it fully depressed. Put six months supply of bounce dryer sheets in plastic bags everywhere on it. Mice and little critters don't like that stuff. If you have wood rats expect to find a lot of damage, darn critters like rad hoses. leave it full of fuel with a shot of additive to keep mold from growing in the fuel.
/ storing tractor for years #20
Definitely do not drain the fuel. That will likely mean that condensation will get to where you don't want it. Stabil is not the product for diesel fuel. The fuel itself will be fine, but it's algae that is the problem. Condensation leads to moisture in the tank and then algae will develop. Fill the tank all the way and add some algecide. Put fresh oil in the engine to keep acids from damaging the iron parts.
You'd be much better off running it once in a while than leaving it for two years. Long periods like that are hard on equipment. It leads to stuck water pumps, flat spots on tires and condensation in the gear box and in the engine. By the time you do all the suggested preparation that everyone has mentioned, you might be a lot better off to just run it every three months or so to get it fully up to temp and moved around so that everything gets exercised and lubed, and the tires rest on new spots. I would just store it with a battery tender connected and run it every three months. Check the tire pressure each time you do and get it up to full operating temp each time. Do not leave it in the sun or outside. If you are worried about rodents, the dryer sheets sound interesting, or mouse bait.
If you really don't plan on running it for two years, it's probably better to sell it and get another one later. Or leave it at a friends house to get run and worked once in a while.
Deere 310D Backhoe (A64047)
Deere 310D Backhoe...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63118)
2017 Cadillac...
2020 John Deere 1770NT Planter (A63109)
2020 John Deere...
43023 (A59228)
43023 (A59228)
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
Arrow Quip 10' Corral Panel X 5 (A64047)
Arrow Quip 10'...
