Front ballast / Suitcase weights - DIY or cheap
   / Front ballast / Suitcase weights - DIY or cheap #1
travelrider73
Member
Palmetto, FL
Kubota B7100HST
I need some front weight on my tractor when moving one of my heavier non-ground engaging implements (a wood chipper).
I'm hoping for a DIY / cheap option because I was a little surprised at the cost of proper suitcase weights.
I do want the weight removable without it being a major project. My perfect setup would be something like six 50lb suitcase weights for a total of 300 pounds. That way I could lift them off by myself. Any DIY options to accomplish the same thing?
The one thought I have had so far is to bolt a rod to the front of the tractor and then go to the used sports equipment place and buy some 50lb barbell plates -- then just stick a nut on the end to hold them there.
Any other ideas?
   / Front ballast / Suitcase weights - DIY or cheap #2
Please don’t do that to your Kubota.
   / Front ballast / Suitcase weights - DIY or cheap #3
   / Front ballast / Suitcase weights - DIY or cheap #4
What are your fabrication skills?
   / Front ballast / Suitcase weights - DIY or cheap #5
I have a vision!!! Mostly of me skinning my shins on the bolt sticking out!!! :)
Depending on his tire size, that bolt may be closer to waist height, Richard....
   / Front ballast / Suitcase weights - DIY or cheap #8
Go for it op, most of our machines stay hidden on our properties where nobody is judging your ballast.
   / Front ballast / Suitcase weights - DIY or cheap #9
I use an old cast gear on my Crapsman tractor for ballast.
Years ago I heard that tractor pull guys would make fake weights out of balsa wood to fool competition who would count their weights trying for the same results.
The old saying- Believe half of what you see and none of what you hear.
It's a freakin B7100!!
Yeah, that's why I need ballast (and a bigger tractor). I'm starting to shop for a 40hp-ish tractor, which is why I don't want to spend any money on this ballast. if it was for long-term, I wouldn't mind, but since this is a relatively temporary need, I'm trying to be cheap. Heck, I'm not even sure this tractor is going to run this chipper. That's test #1. It's a 650 pound 6" chipper and my PTO is 5hp short of the minimum recommended. I am hoping I can slip the clutch slowly, get it running and then just not try to make it chip big logs for now, but that's a different topic.
The topic at hand is: I can lift the front of my tractor off the ground with one hand right now with the chipper attached and raised up. I can't steer! LOL.
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2019 Freightliner M2 106 Utility Flatbed Day Cab Truck Tractor (A55973)
2019 Freightliner...
utv cart Honda (A56857)
utv cart Honda...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
