GC1710 Dashboard lights not working.
   / GC1710 Dashboard lights not working. #11
they need a good ground too, check that, also, if the power to those lights go through the ignition switch, that could be a cause too..
I dont think they go through the switch. I can cut my lights on with the key off and in my pocket. May need an ohm meter to ohm out ground and check for power. Also 2017 should still be under warranty.
   / GC1710 Dashboard lights not working. #12
so there must be a light switch for the dash lights then, if so, check for voltage on both sides of the switch..
Thanks for all the helpful suggestions. Still working on a diagnosis at this point.
After much troubleshooting I towed the tractor to the dealership. Three weeks later they were unable to diagnose the problem and have turned the issue over to MF. Its being covered under warranty, they are unsure of the actual repair time as of now. Ill post further info once I actually hear what the problem is. Sucks how many tractor jobs you find around the property when the tractor is gone! Lol
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55301)
PENDING SELLER...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
