Loader New CK3510SE HC question
/ New CK3510SE HC question #1
Rick Moen
South Dakota
JD L120, Kioti CK3510SE HC
I just bought a new CK3510SEHC and on the loader level indicator when the bucket is level there is about 3 of rod above the indicator tube. Do I cut the excess off or is this the way it is supposed to be? I thought the rod was supposed to be flush with tube when level.
/ New CK3510SE HC question #2
That's what I did.
Just make sure the rod can't come out of the tube at full extension once cut.
/ New CK3510SE HC question #3
My older CK30hst had a pin on bucket. A few years later, Kioti made the loader with a QA. I purchased the QA, which fit perfectly, and bought a bigger QA bucket. Leveling the bucket now had the rod sticking up @3 inches. After measuring, I sanded that extra rod area lightly and painted it white. So far it has worked for me.
/ New CK3510SE HC question #4
/ New CK3510SE HC question #5
the rod should be even when the bucket is ON THE GROUND, level. If not, it's probably adjustable. As you raise the loader arms the bucket will not remain level on it's own, and the indicator won'd show level.
/ New CK3510SE HC question #6
Slide on a piece of rubber/plastic hose.
/ New CK3510SE HC question #7
I got the idea from Billrog. Bucket is level when the rod is even with the end of the pex. I cut out a section of the pex so I can now see how far below level the bucket is.
Yes I should clarify that it is when the bucket is on the ground. I checked it on my cement shop floor.
/ New CK3510SE HC question #10
I personally just wrapped electrical tape for a level marker. The stock set up is pretty silly to me. But any mod that makes sense to you will work obviously!
2019 John Deere 1023E Tractor (A61166)
2019 John Deere...
2005 Kobelco 135SR Hydraulic Excavator (A61567)
2005 Kobelco 135SR...
Wooden Three Headed Native American Statue (A61569)
Wooden Three...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
