Diggin It
Super Star Member
Currently have a conventional LP forced air furnace with ductwork. Also a cast iron wood stove. Both have a list of pros and cons. Biggest issue with the furnace is the electric use and noise of the blower. Wood stove is silent, but takes a lot of work to supply. Thinking of future years when physical abilities may begin to wane, I need to consider alternatives.
I've looked at LP burners before, but never really got serious. I have an old one that was left with the house. Moved it to a back room breezeway between the house and garage to keep the chill off, but I don't try to heat the house with it due to the location.
I'm seeing some better prices now on LP ventless fireplaces. I have a spot in the LR where I could install one in a corner. It would be more centrally located than the one in the back room and the woodstove. But I'm trying to figure out how well it might heat the house as a more or less primary source. This is a fairly small story and half house, about 900 square feet on the ground floor, about half of that upstairs which I don't really use in Winter. We generally don't get long cold spells, but we have on occasion been below freezing for several days at a time.
I don't like the house too warm. T-stat is set at 60 and the wood stove usually keeps the place above that when in use.
I'd like to cut the electric use of the furnace blower, but I'm not sure how well these LP heaters heat rooms other than the one they're installed in. And I don't want it sucking too much LP which also costs money.
So, does anybody use these as a more or less primary heat source? How well do they work? And how much gas do they use realistically?
