MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,711
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
A simple hypothetical example. A hyd system designed to leak at a rate of 1 drop per minute. Extend the lift cylinders on a loader. If the piston seals are faulty, you now have not 1 port leaking at a rate of 1 drop per minute, but 2 ports leaking at a rate of 1 drop per minute. Thus doubling the 1 drop per minute acceptable leakage rate and causing concern about drift.
That is the exact reason when testing, you isolate the cylinder from the rest of the hydraulic system. Then try to have the rod extend, if it extends, then you are happy to have bad seals. (easy fix) If not, then you have a poor control valve that typically needs to be replaced.
Yes it is possible to have both bad seals and a bad control valve. But if you confirm that the cylinders do or do not leak is the starting point. If you have bad seals and change them and still have excessive cylinder drift, then you know that the control valve is out of spec and should be replaced.
A good rule of thumb IMO, if the drifting actually affects you operating the tractor, then the problems need to be addressed. If not and you find that things move after days or weeks, not really a concern.
Just my :2cents: , others may disagree and that is fine, I know that this works for me.
