Ratchet Strap with Zip Tie Wrap
/ Ratchet Strap with Zip Tie Wrap #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
I use zip ties to wrap up the long ends of ratchet straps when transporting stuff on the lumber rack. It is quick, neat, and fail-safe.
/ Ratchet Strap with Zip Tie Wrap #3
Invest in some if the reusable zip ties. They will pay for themselves over time
If you don’t cut them like the op has done you can open regular zip ties pretty easily and reuse them.
/ Ratchet Strap with Zip Tie Wrap #6
That does not secure them on a trailer at speed.
We use short 1” Velcro straps.
Did you watch the video? What he did isn’t going anywhere.
/ Ratchet Strap with Zip Tie Wrap #7
maybe you should try it first, they don't go anywhere.
/ Ratchet Strap with Zip Tie Wrap #8
If that works for you, terrific. And it is nice this gentleman discovered this hitch, which has been used on sailboats for 100’s of years. Here’s how halyards and sheets are stored. That hitch even has a name.
Au contrair, at highway speeds the roll needs to be secured or it bounces around. We roll the excess as he did, then attach the role to the tensioned part with Velcro straps as the picture above shows.
This boat weighs a couple tons, and tends to walk backwards on the trailer. We had four straps on it: two over the top and two securing the keel forward on the trailer. If his technique works for you, great! On a 600 mile tow, spending $6 on Velcro straps seemed reasonable. It is very quick and easy to adjust if the load has shifted or compressed.
/ Ratchet Strap with Zip Tie Wrap #9
I would stick with velcro or reusable zip ties. No landfill.
/ Ratchet Strap with Zip Tie Wrap #10
i used to use zip ties now i use those long orange twisty ties from home depot - can get different sizes and reuse them -
/ Ratchet Strap with Zip Tie Wrap #11
I use electrical tape. Easily ripped off by hand and comes in long rolls.
/ Ratchet Strap with Zip Tie Wrap #13
x2 on Velcro
/ Ratchet Strap with Zip Tie Wrap #14
/ Ratchet Strap with Zip Tie Wrap #15
There’s a video of a guy rolling a strap on here for storage. I was pretty sure he was over complicating things. I thought you could tighten the strap on itself and after trying it you can. The method works pretty good and looks neat, but I think my old method is less troublesome especially for someone else trying to lend a hand. IMG_0723.JPGIMG_0724.JPG
/ Ratchet Strap with Zip Tie Wrap #16
Yes but who cares? I do my straps that way and yes the roll can bounce around but it doesn’t come loose and if done right it has less than a foot of slack and doesn’t go anywhere.
The zip ties, tape, bailing wire, Velcro or whatever work better and are cleaner but they all require having something extra. I like the roll method because I can do it anywhere with any strap and not need anything else with me.
/ Ratchet Strap with Zip Tie Wrap #17
Yes but who cares? I do my straps that way and yes the roll can bounce around but it doesn稚 come loose and if done right it has less than a foot of slack and doesn稚 go anywhere.
Securing motorcycles for a highway trip, slack could damage the finish or bodywork so I want the $2 worth of Velcro straps.
Also bought some of the self-retracting units but haven稚 used them yet.
/ Ratchet Strap with Zip Tie Wrap #18
Put the ratchet and roll down low on the trailer side not the motorcycle side so it isn't rubbing on the bike?
/ Ratchet Strap with Zip Tie Wrap #20
To save $2?
Probably doesn’t matter if you are towing a tractor down a back road.
I always put the ratchet on the trailer side anyway because it’s a lot easier to deal with it while standing on the ground.
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2005 little wonder high output blower (A64557)
2005 little wonder...
2000 Ford F-250 4x4 Service Truck (A66736)
2000 Ford F-250...
PORTA POTTY (A67714)
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
