Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!!
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #31
I don't believe that's correct. The overflow from the radiator cap goes to the _bottom_ of the burp tank. That's how it's able to draw coolant back in when it cools w/out aspirating any air.
The barb on the cap goes to an overflow hose that is open at the bottom and drains "overboard". At least that's how it is set up on my BX and GR.
thanks,
Z.
I will have to take a closer look then. That is how our B7500 is setup (with both a dip tube that goes to the bottom of the tank and a vent in the cap, it has 2 hoses that connect to the cap, 3 if you count the dip tube).
Aaron Z
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #32
Aaron Z
From the recall notice:
Z
[edit to add] Burp tanks from GR and BX. Radiator overflow hose nipple at bottom, burp tank overflow at top.
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #33
LOL.... you`re absolutely correct...!!!!!!!
Kubota probably thought that people wern`t smart enough to figure it out on their own, so they wasted alot of time and resources instead.
By making assumptions about the intelligence of others, sometimes all we do is provide an insight into our own.
rScotty
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #34
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #35
Okay, the risk must be that the tank will pressurize and then pop open dumping steam all over you.
Aaron Z
That's the way I read it. Not trivial, but more a user safety issue than a serious engine problem.
later,
Z.
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #36
There is a pic. that shows the problem by cutting a good part and a bad part. It clearly shows the injected defective part having a bent down horizontal pin and not lining
up with the vertical pin allowing the flash between the area where they are supposed to meet. ( I have 26 years working in injection molding
Where`s the pic (???)
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #38
Going to have a look today, looks like a 4mm drill will cure the problem if there is a blockage (11/64 is about 4.3xxxmm)
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #39
Pulled it off and is clear so I won't need the new one when it arrives but I am surprised there is no hose into the tank, how does it reticulate what it has emptied into the tank?
   / Kubota Recall - Be Aware!!!!! NOT SURE WHO OR WHAT YEARS ARE EFFECTED...!!!!!!!!!!!!! #40
As mentioned up-thread: the hose from/to the radiator is at the _bottom_ of the burp tank. The hose on the top is an overflow that dumps over the side.
Z.
2018 CATERPILLAR 336F L (A58216)
2018 CATERPILLAR...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2014 Ford F-150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F-150...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
