Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,663
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Today I found after moving palleted items to a woodland area for winter storage I suddenly could no longer get my forks to behave correctly when I move the joystick full left or right. Prior to the problem hindering operation I noticed going full right, fast dump would sometimes render the forks going the opposite of what I wanted them to do. Same thing going full left on the joystick; 'full curl'? I removed the forks to attach my bucket, but could not get the QA plates on the loader to tilt far enough forward to get under the bucket's lip to attach the bucket. I also could not get the 'plates' to retract fully. The cylinders did not completely retract into their tubes.
I looked underneath the right side floorboard to see if any QDs were disconnected, and tugged on each hose, but none seemed to be loose or partially disconnected.
Any ideas on what might be causing this other than a disconnected QD?
TIA,
CM
TIA,
CM
