Question regarding Hay.
/ Question regarding Hay. #1
TheCowboyNation
John deere 40W
So I am a young antique tractor enthusiast of 22 years old and am debating on whether or not to start a small hay bailing operation in my home town to make a little small cash but also to have some fun with antique tractors. I own a John Deere 40w but am looking into buying a Farmall C for a very nice price from this older lady whose husband passed away a couple years ago. I am looking for advice for getting a haybine and a small square bailer that I can use with my Farmall C. Im trying to stay away from a sickle bar mower for maintenance reasons but not close minded to it. I also read a brush hog with no sides would work decently. I live in Florida so hills are almost non-existent but I have gotten a lot of mixed responses about if it's possible or not. Could y'all give some advice on models or if I should even pursue it at all.
/ Question regarding Hay. #2
I'm thinking a Deere 14t baler. Your Deere has a little more power and might handle a 24t.
Unless you want to be completely authentic I'd recommend a small drum mower, either tractor should have no problem with a 48".
Don't expect to make a lot of money and you'll be fine.
/ Question regarding Hay. #3
I'd use a sickle bar anyday before a bush hog.
You bale hay, not bail it.
Ok one more add on. I do plan on doing a full restore on this Farmall C if I do buy it and while I'm at it I wanna bore it to a Super C. So it should have a little more HP then a stock C at PTO. Also I kinda do wanna stay vintage about it in the sense I don't wanna have to buy all brand new equipment for a vintage hobby. Kinda gonna try a show off at my local tractor show for people to learn about the older ways.
/ Question regarding Hay. #5
Agree. I never understood the recommendation that a bush hog can be used to cut hay. Aside from the fact that it mulches the cut grass, it just doesn't cut low enough. Or mine doesn't. The grass is a lot lower down low so you miss a lot of grass. You also need reasonably short grass to rake, I can't imagine dragging a rake over a field that was just bush-hogged.
/ Question regarding Hay. #6
Absolutely correct! Also, I find my sickle bar mower to be of almost no maintenance once I got it all set. I use it a couple of times a year and leave it parked outside and just hook onto it grease it and oil the guide points on the bar and go. If you have rocks or mounds though I do recommend one without a pitman stick, i.e. IH or New Holland with the wobblebox near the sickle head. If you are not going to abuse it like I do and only use it for hay I would also strongly recommend the double guards versus the old style single mower guards as they slide through the grass much smoother. Since I completely went through the sickle and realigned things when I bought it five years ago I have done virtually nothing to it except tighten the main drive belt and reattach a sickle section when I broke a rivet when I caught a steel fence post. And I abuse this mower cutting off up to 3" saplings with it and trimming treelines and willows along pond banks with it. Plus sickles are so much quieter than a bush hog or drum - it is so much more peaceful running them.
/ Question regarding Hay. #7
Growing hay for profit is like making a small fortune in farming. Works only if you start with a large fortune. :laughing:
Growing hay that sells is weather and time dependent. You HAVE to make hay when the sun shines. Waiting after your day job to get to the field, is a risk of wet hay. Then no one wants the mess.
It is NOT just cutting and baling grass. After the first time you hay a field... You've mined the value out of it. Subsequent cuts will be less, nothing is free … It's a crop and must be tended like a crop. Fertilized, weeded, planted, etc.
There is no cash profit in a small hay operation with antique equipment. Just a lot of fun, interesting work, and a mental challenge. :cloud9:
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
Hydraulic Fire Plow Attachment (A61572)
Hydraulic Fire...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
