Weight-4720 Cab
/ Weight-4720 Cab #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Guys,
Anyone have a clue on the weight of a 4720 Cab, 400X loader, R-4s. Its a 2007.
/ Weight-4720 Cab #2
tractor data site says 3860 - without loader. you might be able to find out what the loader weight is on the JD site.
/ Weight-4720 Cab
Thx-surprised it is that low.
/ Weight-4720 Cab #4
filled tires are around 500 each, depending on what fluid they used. I'd estimate close to 1000lbs for the loader, so that brings it close to 6000 lbs total.
/ Weight-4720 Cab
Thx guys- calcium filled R-4's just to the point where rims are always wet, plus 550lb concrete weight block.
Thinking about maybe a new Ranger? 7500 lb tow rating. My trailer is a Peque tandem 14'. Think the ranger would be on ragged edge.
/ Weight-4720 Cab
Just looked at literature I have on a new 4066R cab. That lists a weight of 3770, open station and 4675 cab. I have to believe that there isn't a lot of difference between a 4720 and a 4066.
So 1000 for loader, 550 for weight block gets me to 6225 PLUS calcium filled R-4's
/ Weight-4720 Cab #7
here are some weights that i have gotten from JD literature, my owners manual etc Rim guard, etc
John Deere 20 series compact tractor
open station 3700 lbs assume R1 tires
all models with cab 4345 lbs assume R1 tires
400x loader dry weight 927 lbs.
400cx loader dry weight 1100 lbs
17.5l -24 tires with Rim Guard 589 lbs. 55 lbs of Rim Guard per tire
I have a 4320 with cab, 400x loader, 17.5l-24 tires with rim guard, wheel weights 210 lbs per side, tire chains 375 lbs per set ??? and a 700 lb. snow blower
totals 7945 lbs. Add in the hood guard and some other extras and myself, the tractor is over 8000 lbs. No wonder it struggles to go over some of the hills now.
I weighed the tractor several years ago with only myself and the mid mount mower and it was 5200 lbs, no rim guard or wheel weights etc
Later
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
2013 BMW X5 xDrive50i AWD SUV (A61569)
2013 BMW X5...
Clark CGP40 Forklift (A61166)
Clark CGP40...
2026 Kearney 102"x40' Gooseneck (A62177)
2026 Kearney...
2011 Ford F-550 4x4 Terex Hi-Ranger LT38 38ft Insulated Bucket Truck (A61568)
2011 Ford F-550...
