Swapping rears over
/ Swapping rears over #1
Rakemania
Gingin Western Australia
mitsubishi 26 hp 4x4
Been reading that if i swap the back tyres over right to left and vice versa giving slightly wider tyre width. Question is does it really work and what downsides are there to it.
/ Swapping rears over #2
I tried it but my downside was the wheels had some dimples or indentations so the wheels would seat on the hubs. Even so the width difference was minimal so I got spacers instead, but was the only option. So, depends on the wheel and if it has a deeper dish design.
Take one off and try it, it might work. If the tractor has R4s the wheel will have to go on the opposite side to keep the lugs going the correct direction. Works on some but not on others.
/ Swapping rears over #3
worked on my NH 1620 to fit the chains without hitting the fenders.. nothing lost trying it.. if they are filled I would recommend a buddy to keep a hand on the tire.. also a floor jack is your friend.. lower the hub to get to the right height versus trying to lift the tire to the hub..
Thanks for replies my back wheels are deep dished so probably achieve around an extra 85mm width either side. Also one of my mates uses his three way hitch hydraulics to raise backwheels.
/ Swapping rears over #5
Are the wheel rims adjustable (bolted) or fixed/welded in one position? My 4105's are fixed, but many others can be adjusted by bolting them in different configurations:
/ Swapping rears over #6
I moved my R1 tires on the Kubota L3301 from the scary width of 53 inches to a tad over 66 inches.
Tractor feels way more stable now.
I was ready to dump it before I made the switch as just to uinstable. before
I am now searching for some thing with a resonable price to make fender extentions to stop getting pelted with flying mud clods. After
My tires are filled with beet juice AKA rim guard. So they were heavy yet I was able to do the job alone with a bottle jack and a pair of Jack stands.
:D Al
/ Swapping rears over #7
View attachment 581380View attachment 581381My front & rear wheels have the ability to be set to eight varying widths as shown in the document posted by Wagtail. FORTUNATELY - I had the dealer set my rears wide( 80" ) and my fronts ( 64" ) at the mid point. My rears are loaded with RimGuard and weigh a tad over 1000# each. Changing the set of the rears is not a job I would consider a DIY project.
/ Swapping rears over #8
Massey collector, I have been thinking about putting this on my rear fenders
To help with debri and mud. I found these on ebay.
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
