12 volt diesel pump
/ 12 volt diesel pump #1
Walter L
Gold Member
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
Just a heads up on what i think is a good 12 volt pump for a good price. Ater years of using a hand pump on a 55 gal drum i finaly decided to get a 110 v electric or 12 volt pump due to my advance age, i found this 12 v pump on Ebay and decided to take a chance and wanted to let those that are interested that i was impressed with the quality and feature of this cheap pump, it came with everything except the battery clamps , about 10 of elec cord nozzle and hose and Pump has a cutoff switch and a place to hang up nozzle.
This is the seller i bought from although they are cheaper sellers i liked his rating.
12V DC 2GPM Gasoline Fuel Transfer Pump Gas Diesel Kerosene w/ Nozzle Kit 61385262256 | eBay
/ 12 volt diesel pump #2
I've been using this setup I bought for $67 since April 2017 with no problems. I made a pickup tube for my 55 gallon drum with PVC components.
I considered one of those its a nice set up I have a 55 gal drum setting on a 3 ft hi bench (built 30 yrs ago so i could unload a full drum off of the back of 2 wd PU) setting betwene the 2 diesel tractor stalls, easy to reach either tractor.
/ 12 volt diesel pump #4
I have two 55 gallon drums sitting on patio blocks under a shed. I also have a diesel generator right in front of the drums. One of my tractors fits under the shed right by the generator and I can pull my backhoe up just outside to reach it with the hose. I have my fuel delivered. Costs about the same as on road pump price but I don't have to handle cans OR transport drums.
/ 12 volt diesel pump #5
That pump looks just like a Filrite pump, except blue instead of red, but about half the price (maybe a Chinese copy). I have a 15GPM Filrite that I have been using for over 10 years with no problems but I keep it inside rather than out in the elements. Brother in law got one the same time as me but his was always outside (under a lean-to shed but exposed) and he had to replace his a couple years ago due to motor going bad. I hope yours is of at least as good quality as my Filrite has been.
Gary I doubt that it is as good quality as your US made as it is a Chinese made pump, it does seam to be a good quality as the Chinese are doing much better in mfg. If it lasted 10 yrs then thats all i am probaly going to need.
/ 12 volt diesel pump #7
when people convert pumps for display, they throw out the actual pump inside, they don't want the stinky thing in there, and it would serve no purpose in a display pump anyway, so you could get the actual pump for free, 120V version.. you just have to get a hose and nozzle.. and put an electrical cord on the pump..
2004 Rockwood Freedom 1640LTD 18ft. Pop Up Camper Trailer (A61569)
2004 Rockwood...
New/Unused 60in Pallet Forks (A61166)
New/Unused 60in...
Manure spreader for sale
Manure spreader...
(INOP) HUSQVARNA LGT2654 RIDING LAWNMOWER (A62130)
(INOP) HUSQVARNA...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
