Too Much Tractor?
/ Too Much Tractor? #1
Paultace
Eureka Springs, AR
Kubota MX 5800
Is there such a thing? I did zero in on an MX5800. See previous post with pics of the land... its 24 acres of steep hills completely wooded with about 2 to 3000 foot of dirt road to maintain. I'll have a lot of trees/brush to deal with as will the occasional stump. Lots of large flat rocks I'll use for landscaping to move around.
So... I've not taken delivery but its ordered. In this time and reading several posts I got to wondering did I get too much tractor? Plenty on here saying how much they love their BX, L3301, L2501, etc... and I'm over here like dang... I coulda got 2 2501's for what I'm paying for this MX.
Am I going crazy?
/ Too Much Tractor? #2
Never too much tractor. Better a "REAL" tractor than a toy.
/ Too Much Tractor? #3
I’ve got an MX-5800 on 28 acres and think I need a second tractor if that helps:D
/ Too Much Tractor? #4
You had twenty-two posts in your thread NEWB BUYING A TRACTOR.
Why are you second guessing yourself after placing a considered order?
Has your land changed?
/ Too Much Tractor?
Lol... Not really second guessing. Just maybe bad luck there were a slew of posts of how similar properties had smaller equipment and doing fine. Nah, I'm not calling it off or anything. Just got the 'spending big money' pit in my stomach and need some reassuring. Ha
/ Too Much Tractor? #6
yes there can be to much tractor, (more for the size of the tractor) than the power of it, I farmed for about 40+ years, and still have my old farm tractors, and they are not that big of farm tractor, about 100 hp, but there not good in the tree rows, and the one has a wide axle, not the greatest for mowing unless it is a field, but I did about pull down a windmill with it mowing one time, catching the axle on a leg of the tower,
would love to have a small loader tractor with smaller frame, a bit narrower and able to get in to tighter places, and to use my 5 foot mower in the trees and to use the under fence mower with,
I think for some things your tractors frame size can be to large, somewhat like using a 18" adjustable end wrench (crescent) on a 7/16" nut, it can be done but not handy and easy,
/ Too Much Tractor?
Good info! Thanks!
/ Too Much Tractor? #8
YOU could get by with a smaller tractor.In the 30 to 40 hp range but definetly no smaller.I have 360 acres of hunting property, and its fairly hilly. I have 4 tractors the largest is a 2 wd 55 hp and the smallest is a26 hp 4wd The smaller tractor is great for working in the woods .But is a toy out in the open fields trying to brush hog. I have a 7 ft cutter for the 55 hp massey and even that seems small .
/ Too Much Tractor? #9
Hey - I've got 64 engine hp on 80 acres. But - I WILL TELL YOU THE SECRET ABOUT TOO MUCH TRACTOR. It is seldom spoken and then only in the shadows or the dark corners of forgotten buildings.
You may have too much tractor when - turning the tractor in a 360 degree circle will result in the tractor knocking down all four property line fences. It MAY be time to consider downsizing - then and only then.
/ Too Much Tractor?
Love It! Thanks!
/ Too Much Tractor? #11
80 engine hp, 65 hp on the PTO on a 10 acre lot with a 1/4 mile driveway, around 12,000#s as she sits and its not to big. And she sits next a 55 hp IH 574 which is running as light as possible she's only about 4500# for when the ground is soft. They are both cat 2 on the 3 point hitches.
As far as knocking down the corner markers, that's why we have steering brakes, mash and pivot. :dance1:
/ Too Much Tractor? #12
/ Too Much Tractor? #14
I would say that's just about right for thirty square feet of lawn. In my mind, though, I remembered it being a V8!
/ Too Much Tractor? #15
Am I going crazy?
I agree, the size of the tractor is just fine. Sure you might not need the extra 10 HP over the MX4800 right now, but you might in the future. Stick to your guns!
/ Too Much Tractor?
Yeah... I think this is Exactly what I was looking for. This isn't a purchase like a car... this thing will outlive me most likely.
/ Too Much Tractor? #17
Gonna pass this pearl of wisdom to the wife and see what she says:thumbsup:
/ Too Much Tractor? #18
I have 36 Acres and I also purchased an MX5800 0% down
I ordered the MX4800 and after I ordered I changed up to the MX5800
My property is part Clay and part Shale Rock
several weeks ago I took my tractor up to work on my property (I do not live there full time)
I started digging into the rock with my Backhoe Attachment. Hard diggin for sure.
Went to the Clay and was very happy that I got the extra HP even thou I have never operated any other Tractor before.
I have a friend that operates a company up there with a very large Deere Backhoe and another Skip Loader.
He stopped by to see what I was doing.
He asked me about how I dug the rock and I told him with the Backhoe.
He told me from experience that the problem with small tractors was that they did not have enough weight in them to do heavy work.
He also told me that he was impressed with what the MX5800 did in the rock and added that I may want to add more weight to it in the future with Beat juice and wheel weights . He also told me to weld on an attachment to my Backhoe bucket that would accept a single ripper to help with breaking up the rock before scooping it out of the hole.
I for one am very very happy I went with the MX5800 Lots of potential with attachments as well as a strong tractor.
Have fun with yours and good luck. I went over the side of building a bridge on my property and was puckered up good.
I did not roll it but it was close. My friend came over and helped me pull it back out of the hole and told me I did good by not trying to get it out by my self. He said it would have rolled. That he had rolled several times in his 40 years of operating.
So what ever ya do try an keep the top side up and know your limitations.
Good luck to you Sir.
/ Too Much Tractor? #19
My neighbor has 2 acres - a wheel horse, a craftsman and a new husqvarna all garden tractor/mower type devices. And a farmall M with a loader...doesn't use it much, but does use it.
At the house I too have 2 acres, the farm is 25. I had a 70's L175 and now have a new Kioti CK3510HST.
What is 'too big' or 'too small'? IN the barn the kioti is just about too big - think 300lb man in a small bathroom. gotta go easy or you bump into things. Out in the 15 acre pasture brush hogging for 8 or 9 hours...wish it was bigger.
Brought it to the house for a few days..teh kubota fit nicely, the kioti is a bit large. A smaller B or bx perhaps would be good.
With the kioti I can do what I need to do - move my 7000lb camper, move dirt, brush hog, and soon clear snow. other than the time it takes to brush hog (15 hours...or so) it's fine. Would be a bit much for mowing grass unless you have a football field or such, like the farm neighbor who uses some ancient tractor (think late 30s..it has rubber tires but styling says it's very old) with a 7 or 8 foot finish mower on the back, a PTO driven pull behind. they also have something else very old (no paint on it either) with a belly mower..farmall c or maybe a cub lowboy or similar for around their house.
/ Too Much Tractor? #20
I have 33 acres and got an MX5800. I am glad I did. It has been great for what I need. Part of my thought process was that most implements that I will ever use, this tractor would handle it. If I needed to do something that this tractor would not handle, I probably should hire someone else to do it. Congrats on your new tractor!
LAND PRIDE QH30 QUICK HITCH (A62130)
LAND PRIDE QH30...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61567)
1992 John Deere...
2018 CATERPILLAR 236D SKID STEER (A62129)
2018 CATERPILLAR...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR8EH765283 (A61165)
2014 International...
